Rear wiper, water leak?
Old Apr 13, 2024 | 12:48 AM
BrunoBoy650's Avatar
I’ve replaced all grommets along the rear lower windshield and had also taken the steps of adding some silicone around each one to ensure of no water leaks. I am still getting drops in my trunk right in the center. Could this be the wiper seal? Is there a part replacement for just the rubber gasket? I’ve only been able to find the full wiper arm and if that’s the case, I’ll delete the wiper entirely.
Old Apr 15, 2024 | 10:46 AM
Kevin.'s Avatar
Wiper mounts inside the rear windshield. You'd have leaks on the rear deck lid above the rear seats. Inspect your trunk seal or have someone watch inside as you spray the outside of the car.
Old Apr 15, 2024 | 11:01 PM
Thanks, it’s been raining so I’ll check on the next clear day. Does the wiper use a rubber seal though? In case I want to replace that while parts are still available.
Old Apr 16, 2024 | 08:13 AM
Kevin.'s Avatar
There is a gasket but I'd imagine it's hard to find. If regular Lancers have rear wipers you may be in luck.
Old Apr 17, 2024 | 08:16 AM
I wonder if it’s able to be bought separately .
Old Apr 17, 2024 | 12:44 PM
Kevin.'s Avatar
Everything has a part number, finding it available is the hard part.
LivinloudEvo
Feb 23, 2011 10:08 PM
daisaw1219
Dec 17, 2009 05:56 AM
groundboundMU2
Oct 13, 2006 01:35 PM
AC556k
Jul 12, 2006 07:14 AM
TripleJ03
Mar 20, 2004 03:51 PM
