Help with stock location turbo upgrade!
Hey! This is my first real post here so apologies if the formatting or wording isn’t the best.
I recently picked up a IX GSR a few months ago, and while it wasn’t horrible it definitely wasn’t perfect. After a bit with the car I’ve opted to fully rebuild it as well as I possibly can. It already had a few goodies installed and it’s currently at the shop having the major work done.
However, I’ve found a point of contention: difficulty in selecting the proper turbo. There are plenty of good options and I’ve scoured the forums + Reddit + talked to the shop, however very little of the info is current, and it’s likely new products/options have come out that might be a far better pick for my goal.
The goal is above 500whp without compromising reliability (in a significant way, I’m aware building/modding always has a trade off) and offering decent responsiveness/low turbo lag.
It’s impossible to judge best option randomly, so this is the current list of parts going into the car. Feel free to critique them as well if any issues are spotted.
—————————FIC 1200cc Injectors
AEM 340lph Fuel Pump
FP Race Cast Manifold
Wiseco AP HD Pistons 85.25mm 0.25mm 9.0:1 88mm Stroke
Manley H-Tuff Forged H Beam Connecting Rods
King Bearings Race XP Main Bearings Coated STD
King Bearings Race XPC Coated Rod Bearings STD
GSC Intake Valve Guide Set
GSC Exhaust Valve Guide Set
GSC Power-Division ZERO-TICK Lifters
GSC Power-Division Beehive Spring Set with Titanium Retainer
GSC Power-Division Billet Evolution 9 Mivec S2 Camshafts
GSC Power-Division Intake Valve STD Size
GSC Power-Division Super Alloy Exhaust Valves
GSC Power-Division Viton Valve Stem Seals
STM Turbo to Manifold Stainless Gasket
STM Coil-On-Plug Ignition/Denso Coils
STM OEM Turbo to Manifold Bolt Kit
STM ARP Stainless Exhaust Manifold Stud Set
ARP Custom Age 625+ Cylinder Head Studs
Mishimoto Radiator
ETS Intercooler
The two main options I’ve been recommended are the FP Red and AGT 64mm w/dual ball bearing/twin scroll
Thanks for making it to the end and any advice/opinions are appreciated! Glad to be here.
Mishimoto Radiator
ETS Intercooler
I would ditch the Mishimoto radiator and just run a stocker. If you want to get fancy get the STM Billet slim one but the mishimoto is going to take up more space and cause fitment issues.
Are the FIC 1200's high z? Id go a tad bigger. Clutch and fuel always go overkill. Clutch wasn't mentioned either so consider that one for your goal.
Go with an UHF Red.
Go with an STM Street Core. I dont believe the ETS is a Garret core and although below a certain level itll be fine, it ain't the same.
Go with an UHF Red.
Hard to beat the spool up and power of the MHI red on an 9. 500lb ft around 4000-4300 if you want it.
1200cc injectors on E85 will be maxed out around 500whp. IIRC my ID1300 made about 500-530@ 30psi before being out.
1300's drive excellent , but get with your tuner and see what they like if you want to make more up top. Since its a built engine I would go to 1700's and just max the red out.
Go with an UHF Red.
Go with an UHF Red.
Go with an UHF Red.
Go with an UHF Red.
Thanks for the advice! I’ve heard that issue with the Mishimoto, and not only that but that appears to be somewhat of a sign that the car’s been imperfectly modded.
Clutch was recommended and should very likely get replaced/upgraded, good to hear that’s the consensus for that goal.
I was looking at ID1300s as that’s what I ran in my R35, but am curious to know the real-world tradeoffs between that and 1700s. The S2 cams can make use of either but if I were to do any kind of performance driving, it’s definitely track/autox rather than drag/roll racing. No launches either, the R35 instilled that in me lol
I’ll look into the UHF red now, first time seeing that suggested so curious to give it a look!
It appears to have a no-name midpipe/catted down pipe but that should be swapped out for sure. A lot of this build is learning what the previous owner did and, generally, fixing it. 😂 I’ll be restricted by a cat because NJ but I’d rather be power restricted than constant tickets and stressing about emissions readiness.
Why spend that kinda money when you can just get a CSF core without the upcharge? The STM kits is like 1000 bucks why the **** would you buy that for a street car? I would just get a regular CSF rad get rid of the Mishimoto garbage and put a good fan on it and call it a day. And I agree with the red. Those are no joke and make great power for what they are.
checking out the UHF now, can’t believe I missed these.
I completely understand not wanting to overspend on a street car, however my main question is does that kit garner more stable temps/better overall cooling? I do plan on track days and if it means a noticeable improvement/increased stability then I’d far rather buy once and cry once. Thats, of course, if there’s a real difference rather than the STM branding.
I'm just here giving opinions on things I have run and dynos charts I have looked at when building my setup.
A few 100 RPM difference isn't the end of the world but it can really change the feel of the car around town.
lol, I mean yea, there is a pretty big gap in lag between even a large stock frame setup and something like a 6466 but it is noticeable depending on the driving you want to do.
The 6466 is an upgrade for what I had. I had a journal bearing 72mm turbo. You wanna talk about lag lol. I didn't see 10 lbs of boost till 6800 rpms, saw 20 lbs by 7200 so yeah lag lol. I think i saw 60 lbs of boost by 8200 I believe it was. At least with a 6466 I will see 40 lbs of boost by like 5200 to 5800 rpms. Huge difference lol.
I had a turbo my my old Evo that didn't spool till 4k and even that seemed like a lifetime. That's probably why I will never go with anything larger than stock. lmao
I can't imagine how boring that much lag would be just driving around town. I'm guessing it's only fun full throttle?
