Power steering hose
Old Apr 22, 2025 | 12:24 PM
FabianJ's Avatar
Power steering hose
Hi! I am rebuilding my engine bay and trying to make as clean as possible. I now have some problem with the Power steering hose. Has anybody changed this to something more Nice? Maby re-routed it ? Send some pictures or come with some ideas 🙏
Best regards
Old Apr 22, 2025 | 09:43 PM
osetsky's Avatar
Upgrade to electric system and do away with stuff altogether?
Old Apr 23, 2025 | 04:31 AM
FabianJ's Avatar
I havnt had that in mind. How do i get electric power steering?
Old Apr 23, 2025 | 08:14 AM
osetsky's Avatar
Dow the rabbit hole you go! Somewhere around here there should be a write up on power steering swap, I don't recall exactly which pump but think it's a VW unit and like a beefier alternator?
Old Apr 23, 2025 | 08:29 AM
schuhie's Avatar
Here is a kit I found with a quick google.
https://bdspeedshop.com/products/evo...kit-from-volvo
I couldn't find the write up on this forum but the volvo pump is very widely used for this kind of setup so there are loads of write ups around for how to wire it and such.
Old Apr 23, 2025 | 09:56 AM
ViciousLSD's Avatar
I try to wrap every line with that mesh/flexible braiding
Old Apr 23, 2025 | 12:18 PM
thepoint4life23's Avatar
This might help you out
https://www.evodynamics.com/products...-steering-line
Old Apr 23, 2025 | 01:01 PM
FabianJ's Avatar
Thank you guys for responding! I think i will try to build something in stainless Steel and modify it to look good. I think its to big project to change to electronic PS
Old Apr 23, 2025 | 01:11 PM
schuhie's Avatar
If you are going that route, any local hydraulic shop can make up power steering lines if you want. So it you find a routing that you like, they can crimp one together for you.
Forklift mechanic shops can also do it, depends on the place if they will or won't though.
Old Apr 23, 2025 | 02:49 PM
Kevin.'s Avatar
I put the technafit STM line in and made my pump loud as hell
Old Apr 23, 2025 | 08:11 PM
FabianJ's Avatar
yeah I've heard that some has problem with this. I wonder why ?
Old Apr 24, 2025 | 07:50 AM
Kevin.'s Avatar
Something tells me it's a higher pressure. I want to swap back to stock if I can find a nice pressure line.
raverthug
Dec 25, 2020 05:14 AM
mithrandir7533
May 15, 2014 11:23 PM
kanyonkid
Jun 9, 2010 01:17 PM
