Evo 8 Misfire
Old Dec 23, 2025 | 07:30 AM
schuhie's Avatar
Originally Posted by flux135
We have tried it on the oem coils and it missfires. What do you mean by SD?
Speed density. Or are you still running a MAF?
Old Dec 23, 2025 | 09:28 AM
ViciousLSD's Avatar
did you only replace the coilpacks or the 4 plugs are also new?
Old Dec 24, 2025 | 08:38 AM
Boomfist's Avatar
Is it a misfire or like a stutter? I had a similar issue where the car runs fine until 5k rpm and then there's was a stutter/misfire. Turns out the cam sensor was loose and what make the car temporarily read 0 rpm once it hit 5k
Old Dec 24, 2025 | 11:15 PM
ViciousLSD's Avatar
I remember a guy who posted about his pcv (recirc?)hose coming off and getting oil into the cam sensor plug that caused problems.
also check the ground wire in that area. that thing is brittle
Old Dec 25, 2025 | 12:32 PM
Alberto0216's Avatar
Check for boost leaks
What does the car have as far as upgrades? Aftermarket parts? Even a hose coming off for emission like the common hose that comes off from the fuel regulator!
Old Dec 31, 2025 | 05:18 AM
Ozwald's Avatar
Veteran: Air Force
What injectors are you running?
After the misfile does it continue at higher RPMs >4000?
Old Jan 12, 2026 | 09:18 AM
flux135's Avatar
Originally Posted by GTS4Life
Did you ever get this diagnosed? I think I'm having the same issue.
Yes we got the issue fixed it was the fuel pump was starting to go. The evos fuel pump runs on 10v when idling then moves onto 12v under load which is why it could rev to 8000rpm no problem when stationary. Take the car down a hill and see if it will rev past 4000rpm as the fuel pump does not have to work as hard.
Old Jan 12, 2026 | 10:04 PM
matane's Avatar
nice diag
Old Jan 20, 2026 | 04:18 AM
Alacris's Avatar
Not to hijack -- but this stutter problem sounds exactly like what I've been experiencing off and on the last two years. What do you mean by the cam sensor? The crank position sensor or is there another one? Thanks.
Edit: For the OP -- I don't have misfires on cylinder 3, but it's always my ugliest spark plug when I change them. Someone here said they look like that one runs a little lean. I'm not good at reading the plugs. Saw that you got it fixed -- good job.
Last edited by Alacris; Jan 20, 2026 at 04:21 AM. Reason: Read farther down and saw OP fixed it.
Old Jan 22, 2026 | 01:56 AM
patric78's Avatar
Hi, I also experienced some stutter when accelerating.
One of the spark plugs got somehow as bit loose, replaced all of them to be on the safe side and the stutter was gone for good.
Old Jan 22, 2026 | 04:05 AM
Alacris's Avatar
My cam sensor looked fine. A little oil weepage, but that's just an O-ring replacement or RTV the cover there. But it was solid.
Definitely had the loose plug happen before. I guess it might have happened again, but I did check them last summer. I have a head gasket job coming up (other thread), but I'll take a look at everything in cylinder 3, check the threads, see if that's where my head gasket blew out (minor blowout, but still needs addressing).
DSMvsWhatever
Jan 10, 2010 09:25 PM
NYREDEVO
Nov 13, 2008 06:04 PM
berkel
51
Apr 7, 2006 08:54 AM
awitron
Oct 5, 2005 10:29 AM
LpBevoEvo
Sep 27, 2005 11:29 AM
