New injectors scaling HELP
Old Sep 10, 2025 | 08:17 AM
Luca Bernardi's Avatar
New injectors scaling HELP. "SOLVED"
Hello, i have big problems scaling new injectors for many reasons:
- I can't log fuel trims, none of the 4, everything remains at 0
- I tried to work on open and closed loops for fuel but my actual tables are all set to 0 ,im always in closed loop?
-all my xml definition files are completely different from the ones stated in the ECU flash guide
I really can't do anything at the moment, can please somebody guide me in the process
Thank you very much
Luca
Old Sep 11, 2025 | 06:31 AM
KK0ng's Avatar
post a screenshot of your evoscan
Old Sep 11, 2025 | 06:41 AM
audiofan's Avatar
What injectors are you trying to scale?
You could try the scaling table in merlins tuning guide as a starting point, and then you can make adjustments
Old Sep 11, 2025 | 01:27 PM
thanks for the reply and sorry for the delay,
this is evoscan and ecuflash
main page
main page
edit of LTFT
edit of LTFT
one quick log with values at 0
thus is the openloop
thus is the openloop "problem" with the actual scaling, it work, but i can't make adjustments without LTFT
Old Sep 11, 2025 | 01:32 PM
Injectors are DW 800cc, i already have all the tables and everything, and are working "fine" but i can't log parameters for making the adjusments
Old Sep 12, 2025 | 01:04 AM
KK0ng's Avatar
main page
main page
edit of LTFT
edit of LTFT
LTFT sometimes doesn't populate until you actually drive the car for a short time (30 seconds or so)
for the logging in live tracer, you cannot have values set to Auto, you have to correctly define the values that match your tables from the dropdown menu, else you will get skewed data
but from my opinion you should only use LTFT to check the correction, and log AFR with a wideband and log the correction vs actual values to dial in scaling & overall base fuel calibration before moving to actual tuning
Old Sep 12, 2025 | 01:15 AM
I tried various methods, disconnect battery on every new injector update, leave the car in idle for about 20 mins, a slow drive for about 15mins, but nothing...it does not show up LTFT...i read that can be the open/closed loop...can be also this in addiction of the dropdown menu?
I have a Wideband connected, and now in idle Is 13.0, thats why i wanted to correct a little bit, overall Is "decent" but running pretty rich
Old Sep 12, 2025 | 02:05 AM
KK0ng's Avatar
13.0 (should be 14.5-14.7) would definitely overcorrect, are you getting o2 readings ? log your STFT and set your openloop throttle to 75, and load should not be % but load based that matches the load calc and set those to 120 ish (just at boost )
Old Sep 12, 2025 | 02:56 AM
I have just the front O2 sensor, the second Is deleted, later i will change the open loop settings and try again, i will update when i have news, thanks
Old Sep 15, 2025 | 04:12 AM
So, i made some work and searched around...since i don't have the rear O2, was disabled in the FEA Bits...i activated this and the O2 simulation in Tephra Tab...set up the open/closed loop in FAA bits...but still nothing LTFT don't show up, nether the STFT
Old Sep 15, 2025 | 05:23 AM
KK0ng's Avatar
almost feels like an openport issue, can you try with an openport 2.0 connector?
Old Sep 15, 2025 | 05:28 AM
No at the moment, i need to eventually buy one...front O2 readings are shown...but now i saw something regarding the MAF Hz and LT...my values are 85 for low, and 1500 for high...and i think this can be the issue...my low Hz reading in idle Is around 35
Old Sep 15, 2025 | 07:05 AM
Those are the actual parameters that i think prevent me to log LTFT
Old Sep 16, 2025 | 10:45 AM
KK0ng's Avatar
seems high, mine are usually around for LT trim control
57
44
1598
1591
Old Sep 16, 2025 | 11:02 AM
57
44
1598
1591
In fact this was the issue i think, i found some lower values on the forum and now everything is working properly, thanks to everybody, i will edit as solved
