Evo GeneralDiscuss any generalized technical Evo related topics that may not fit into the other forums.
Please do not post tech and rumor threads here.
Hello,
Earlier I posted about a fuel leak I had I found that it the gas was spraying out of the end of the fuel feed line after I knocked it while in the engine bay. I’ve been trying to remove the fuel feed line but it seems impossible to wrench off even with a line wrench and this seems to be a common issue. Do ya’ll think it would be ok to slap on some kind of sealant like jbweld (im not sure what would work best) or could I weld the line? I saw others had issues with the fuel feed line and did some kind of hard line bypass but I’m not really sure how to do that. Thanks
Don't screw around with something half-assed like JB Weld when dealing with a high pressure fuel system. If that leaks while you're driving, and sprays fuel all over the engine, you'll likely have a fire and burn the car to the ground.
When I replaced this section of feed line years back, I cut the rubber line as close to the metal hard line as I could. Then, I held the hex of the hard line with a line wrench and used an impact gun with a deep well socket on what was left of the (now cut) feed line.
