Trouble Help
Old May 6, 2004 | 02:30 PM
lanevokai's Avatar
Old May 6, 2004 | 02:31 PM
lanevokai's Avatar
it's me again one more thing should i just reset the ecu anyways just to see if it would make any kind of diffrents even though the problem i had is already fix
Old May 6, 2004 | 04:14 PM
evoD's Avatar
heh...ok yea...a loose clamp will do that too...glad u found the problem. next time look around a lil before u post something...u'll be suprised at what u can find urself =) take care an' enjoy
Old May 7, 2004 | 09:01 AM
Secret Chimp's Avatar
Yes, reset your ecu anyway. Especially if you are not sure if it was done during installation.
I'd bet that the feeling you get in the upper rpms has more to do with the hot weather. If that feeling bothers you, send your ecu off for a reflash/retune. I have a Dynoflashed ecu right now, and I can personally say that it really kicks up the top end power a lot. But there are other tuners that offer this service also. Works and Vishnu are two others that come off the top of my head.
Good luck! Glad your car is fixed!
SC~
Old May 7, 2004 | 09:51 AM
lanevokai's Avatar
Talking
thank u i greatly appreciate this
Old May 7, 2004 | 10:01 AM
DocMortal's Avatar
Most users feel a powerloss with a new intake because of the ecu pulling timing....or running lean or rich?
I just put a drop in K&N filter and works great stock...With stock airbox...stock is cold air
Anyways With dynoflash all my mods are working together and makes awesome power...spend $200 bucks and get the mail in flash from dynoflash,trust me it will run much better and the car will be tuned to your intake...
Old May 14, 2004 | 02:18 PM
evilevo8's Avatar
Originally Posted by lanevokai
GREAT NEWS EVERYONE i found the problem. durring my lunch time i look @ all the hoses and found one that the clamp wasn't even tighten. after i tighten it i was fix. ....thanks to everyone who took their time to help me one more thing though ...............after the aem intake ...the engine spoons up quicker to 3000rpm and makes that koo sound i like. is it me or does the car seem a bit slower at the top end. overall i ran my car very hard to test it's potential with the aem and seems slower or is it just me i figure with the aem i would be faster ...it's like someone had mention in the other threads .....you'll spoon quicker to turbo but your top end is slightly weaker....he said something about only getting less than 19psi like boosting only 15-17psi is that true...or could i just be paranoid....
I have the same problem after installing my AEM intake, the turbo spools faster but it seems it lost that top end kick. i'm willing to sacrifice a lil top end for the sound the intake makes i guess i'm going to get my ecu flashed and tuned on the dyno when i get extra cash. some people say that you lose a little torque but gain a few ponies with the AEM SRI. do you also get a few idling issues like when your driving? then when you go at a full stop your car seems like its going to turn off then you have to pump the accelerator to idle correctly. this seldom happens but it did die on me a couple of times when i was pulling up my driveway. so far i'm happy with my AEM intake no matter what other people say to leave it stock.. it just needs to be tuned to the liking of the installed intake then it won't have them minor issues i guess.
