Greddy e-o1 settings! help!
Old Jun 1, 2004 | 06:18 PM
DARKMETHOD's Avatar
Question Greddy e-o1 settings! help!
hi fellas,
i just got my bc greddy e-o1 installed today and started to play with it in auto setting to run it between 3rd-4th gear but it's retared or something 'cause it stay's at 10-11psi. i want it at 20-21psi, and i figured it has to be done in manual mode but really don't want to hurt my evo.
so if any of my evo brothers out there can help me out here.
thanks fellas-
Old Jun 1, 2004 | 10:36 PM
savageevo's Avatar
Talking e-01 try these settings
You will never get it to work in auto mode. I have tried with the same results as you have. you will have to go to manual mode. ma\y settings are 61 for duty cycle 10 for gain and start boost at 16. my boost stays at 19 psi. When you increase the duty cycle to 62 or 63 I usually boost around 20ish. I do notice when I am on the freeway at 61 duty cycle I could boost up to 20 psi in 4rth and 5th. I hope that helps.
Old Jun 2, 2004 | 05:05 AM
DARKMETHOD's Avatar
thanx, i'll try it and see how it feels. don't know whats up with auto mode! but i knew i would have to set it in manual mode. i'll try it and give an update later.
Old Jun 2, 2004 | 02:02 PM
BRKENG's Avatar
Hi,
Similar deal here
I run in manual mode.
I also use offset boost to keep from overboosting too soon.
offset boost settings
RPM Duty Cycle
4500 0
5000 0
5500 1
6000 2
6500 4
In manual mode on main screen
Duty cycle 58
gain 11
start boost 16.5
I would suggest playing with your offset numbers a bit.
Hope this helps
Don't worry about blowing things up as long as you keep the boost below 20psi. Make sure you use the boost cut feature. Make it like 30% cut. I have mine set to kick in at 19.6 PSI so i dont blast out the thing.
Tim
Old Jun 2, 2004 | 02:32 PM
DARKMETHOD's Avatar
thanx tim, i've gotten some good info from here and via pm. i'll give it a try and let everyone know by updates. thanx again all .
Old Jun 3, 2004 | 05:08 AM
DARKMETHOD's Avatar
update:
i gathered all the info from everybody here and tried diffrent settings and what i got was 61 set, 10 gain, 13 start. this setting just put my head back in 2nd and 3rd & 4th forget about it! man this boost controller was just waiting for me to know how to play with it. i hit 19.6-20ish psi and that was enuff to put a smile on my face. bar none this is the best boost controller i have ever had!
thanxs fellas for all the input and settings
Old Jun 3, 2004 | 02:11 PM
Jadiem's Avatar
i have mine set as follows:
Set = 66
Gain = 8
Start = 18.2
i tried:
Set=65
Gain=10
but the turbo kept maxing out before redline, not that it's a bad thing, but it would boost then quit, boost then quit
Old Jun 3, 2004 | 02:49 PM
DARKMETHOD's Avatar
i think this should be a sticky, just incase more evo owners decied to get a greddy e-o1 BC. i was really surprise there wasn't one already. just fyi to the mods.
