Cut the Evo's weight by 80 pounds - free!
Old Jul 15, 2004 | 10:07 AM
  #31
gt40's Avatar
and from running with only about 1/4 tank of gas.
You are risking a lot running that low and cornering. autox you might get away with it but on a sustained corner the fuel will go to one side and you could suck air. On boost that means one sound...BOOM
Old Jul 15, 2004 | 10:36 AM
  #32
plokivos's Avatar
you do know that 1/4 tank indicated on your instrument panel means you have around 6.5 gallons of gas, right? You have a 4 gallon reserve on your car for things like that. So if you're low on gas your car wont blow up from lack of gas. Besides, you have the mas air sensors to predict low incoming fuel so it'll adjust or shut down the motor accordingly.
you're running rich anyway, it may do some good. lol.
Old Jul 15, 2004 | 10:48 AM
  #33
keviin's Avatar
I was so concerned about weight reduction that I had surgery to remove my thingy... now I weigh 8 pounds less....
Old Jul 15, 2004 | 11:14 AM
  #34
plokivos's Avatar
only 8 pounds? wussie.
Old Jul 15, 2004 | 01:45 PM
  #35
hueman's Avatar
jbrennen... i've been thinking about getting the custom jic coilovers from FT as well. how's the daily drive? any other insight on the settings? where'd you get them installed and set up?
thanks
Old Jul 15, 2004 | 02:04 PM
  #36
jbrennen's Avatar
Daily drive is fine. With the dampers on full soft, the ride is not much different than stock. Occasionally, you hit some bumpy pavement which really makes the car bounce around, but that's not that common in my area.
I've done all of the work myself, including initial installation, later adjustment of the ride height, and adjusting the alignment. If you do the install yourself, figure on at least 4 hours work, assuming you have the right tools. Impact tools help a lot, but it can be done without them.
If you want, FT can set you up with an installer and with corner weighting, and I guarantee you'll pay less than you would taking it to your local performance shop.
EvoDan2004
1959
Jun 4, 2025 12:32 PM
David Buschur
165
Feb 6, 2010 09:47 PM
9sec9
Mar 15, 2009 09:32 PM
David Buschur
18
Mar 5, 2008 09:02 AM
Tarmacisback69
Jun 4, 2007 08:52 PM
