I need help finding a carbon fiber steering column boost gauge mount !!!
I have found this several times and cant seem to find it when i want to order it. It is a carbon fiber steering column mount that wraps around the entire thing and holds the gauge in the middle. Please help me find this.
Hmmm, I don't know about wrapping around the entire thing but this one(RMR) sits on top of the steering column and is held on by adhesive. http://www.lancershop.com/gauge_pods.htm
It's not held on by adhesive, but by two screws that mount through the bottom of the stock column cover into the CF. You won't see the screws as they are inside the pod.
(Mind you, this is how mine is installed and how RMR instructions provided.)
Beware if you are using a boost gauge with a thick outer ring. I have the Defi BF 60mm and the bottom of the steering wheel rubs on the gauge when I turn the wheel more than 160+ degrees. (which is pretty much anytime you park or pull into a garage.)
