Variable Valve timeing?
Old Sep 25, 2002 | 12:55 PM
xcdan's Avatar
Variable Valve timing?
I cant remember... does the 4g63 engine have any type of variable valve timing?? and if it does, can we expect to see that on the evo VIII??? thanks for you comments, I dont know how that works with a turbo, but I suppose porsche does it on their turbo, with variocam or whatever its called. thanks again
Old Sep 25, 2002 | 01:21 PM
Guack007's Avatar
If im not mistaken doesn't the STI use variable valve timing???
Old Sep 25, 2002 | 01:40 PM
Pimpson's Avatar
No and No. boxer 4 vs. inline turbo 4, each without any sort of Variable Valve Timing...here's what one site had to say about the new STI.
Compared to the Evo 7, the STi is a bit more sluggish, with a heavier gearchange and softer throttle response and brake pedal but its still very potent compared to anything else on the road
Old Sep 25, 2002 | 02:25 PM
3K's Avatar
3K
Guack 007 is correct the sti does indeed have variable valve timing. (intake cam)
Old Sep 25, 2002 | 02:28 PM
Pimpson's Avatar
which version then? The info I was able to obtain from Subaru Tecnica International on the 2003 didn't mention VVT at all. They do have like 3 STI trim levels now though.
Old Sep 26, 2002 | 01:21 AM
Guack007's Avatar
Old Sep 26, 2002 | 09:19 AM
erikgj's Avatar
All JDM WRXes and WRX Stis have variable valve timing on the intake cam. The euro STi does not I believe.
No Lancer Evo's do.
Erik
Old Sep 26, 2002 | 12:34 PM
xcdan's Avatar
Why dont they add that feature, wouldnt that increase the output a bit?
Old Sep 26, 2002 | 01:00 PM
3K's Avatar
3K
It would probably increase the hp significantly but R&D equals alot of $$$$$.
Old Sep 26, 2002 | 01:35 PM
Guack007's Avatar
I know that R&D costs money but winning in the WRC can be fairly profitable and a new engine feature could help them against the smaller cars.
I mean come on is currently tied with skoda for 4th and they only have 8 points.
2002 World Manufacturers Championship
Manufacturers Points MC SE FR ES CY AR GR KE FI DE IT NZ AU GB
1. Peugeot 131 4 16 16 16 16 0 9 6 16 16 16
2. Ford 86 10 6 4 5 2 14 14 14 5 7 5
3. Subaru 46 12 0 4 4 7 6 2 0 5 2 4
4. Mitsubishi 8 0 3 2 1 0 0 0 1 0 1 1
5. Skoda 8 0 0 0 0 0 5 0 3 0 0 0
6. Hyundai 6 0 1 0 0 1 1 1 2 0 0 0
-. Citroën* (31) (6) (0) (3) (4) Np Np (1) (6) (0) (10) (1)
*: Not officially part of the 2002 manufacturers championship
Current WRC standings
Old Sep 26, 2002 | 03:54 PM
astondg's Avatar
Even if mitsubishi had it I doubt they could use it the WRC, and they are restricted to 300BHP anyway. Mitsubishi already has some things on the road car that they can't use in the WRC, like when they were disqualified from the Australian round a couple of years ago because they had to replace a turbo just before the event and they forgot to blank off a cooling pipe that the road car has but they can't use in the WRC. Anyway just remember that the WRC cars are nothing like the real cars, the current leader doesn't have an awd car and Subaru is using a front mount intercooler (these are just two small differences).
Aston
Old Sep 26, 2002 | 03:59 PM
ishi's Avatar
Yeah it isn't doing too good this year but that has to do alot with a new chassis replacement (VII) and a new driver bugs.. Once the car is set up for the likes and dislikes of the driver, more comfortable he'll be in the driver seat. You guys have remember, bent over backwards for TOMMI and he ended up leaving anyways. There's always growing pains when your co. changes car and driver in the same season...Hopefully, WRC2 will get some of the handling problems worked out. Remember, Mc Crae and FORD went through some of the same headache.
