What the heck is this
Old Jun 18, 2004 | 07:00 PM
smokymtsguy's Avatar
I have 500+ miles on my Evo and am breaking it in properly. A few days ago after it had sat a couple of days, I started it and after I engaged the clutch I noticed it hesitated and almost felt like I had the emergency brake on before it realeased and moved normally. yesterday, again after sitting a couple of days, I started it and this time is was even more noticably, after i engaged the clutch, it did nothing and then made a slight sqeeking sound and suddenly broke free and moved normally. It has never done this when it is warmed up. Anyone else experience this?
thanks
Old Jun 18, 2004 | 07:10 PM
SinCityEvo's Avatar
Did you wash your wheels just prior? Sometimes the brake pads "stick" after the rotors get a slight rusty coating after getting wet and sitting, then when you drive off, it will feel like it breaks loose for a second and then everything is normal once you clean off the rotors by braking once you are rolling.
Old Jun 18, 2004 | 07:15 PM
[QUOTE=SinCityEvo]Did you wash your wheels just prior? Sometimes the brake pads "stick" after the rotors get a slight rusty coating after getting wet and sitting, then when you drive off, it will feel like it breaks loose for a second and then everything is normal once you clean off the rotors by braking once you are rolling.[/QUOTE
Yes, I did wash it both times. Sounds like that is what happened. Thanks
Old Jun 19, 2004 | 05:40 AM
OnlineAlias's Avatar
Also, after this happens the brakes will tend to make a lot of thumping noises until the rust is removed. Takes a few miles...
Old Jun 19, 2004 | 06:01 AM
Thanks, I feel much better about this.
Old Jun 19, 2004 | 06:06 AM
schleppy's Avatar
Yep, it was just your rotors rusting up, nothing to worry about :-)
Old Jun 19, 2004 | 07:38 PM
BuLocal's Avatar
Agreed, freaked me out the first time it happened!
Old Jun 19, 2004 | 07:50 PM
Autoxevo's Avatar
Ya I washed my evo then parked it in a garage and set the hand brake, tried to move it after a month, it wouldnt budge, ended up pulling it backwards with my Jeep to free the brakes. Heck, even before I get the car dried off the rotors have rust on them.
