noise when turning fast.....
when i turn at high speeds i hear a clanging noise from under the car......what can this be? i figured it was the dp or exhaust loose so i tightend them.....but its still there...
well befor i take it to the dealer finally....imma try to hear somfin here...
it only happens when i turn right at high speeds....its a clanking noise from the front end of the car....never heard it when turning left...any ideas???
oh...BUMP!!
oh...BUMP!!
I don't hear any noises except like a rubbing sound but it could just be the very sticky tires? do you have a brand new evo? if you do take it to the dealership and let them fix it.. we didn't pay $30,000+ dollars for it to be making noises this earily?
The same exact scenario occurred to me as well. When i made quick fast turns i would hear a "clanging" noise while turning then it would dissappear durring the straights. After some investigating I discovered that the exhaust midpipe (hks) was hitting the driveshaft joint. I noted mild dents on the resonator midpipe, to alleviate the problem i simply loosend all exhaust bolts and retightend them making sure that the midpipe was further away from the driveshaft......and since then haven't heard anymore "clanging"
randy
randy
I'm hearing the same clamping noise too, I just installed a Magnaflow High Flow Cat.
Same scenario when turning right I would hear it, some light throttle then I would hear it too.
I don't know where its coming from, I have to check under the car tommrow when its bright.
I already checked under the car, the higflow cat and cat back isn't touching against the driveshaft.
It sounds like in the engine area, like a loose bolt clanging on a metal piece.
Do you have the same noise?
hey i just got back inside too.......well nothing is touching nothing... its like a metal on metal noise....guess i'm headed to the dealer tommorrow.... most likely there gonna say it's my fault because i didnt use my turn signal once or twice while turning.....this is bull
Please post results, becasue I get this sound sometimes too. Its kinda a "Woooooo" sound.
I thought it was an alignment issue on hard rights. Its definitely not my exhaust, as it did it on the stocker.
