Muffler change only?
Old Jul 26, 2004 | 01:50 PM
spyderx's Avatar
I've noticed the stock exhaust on my RS is pretty decent size. Just thinking of swapping out the muffler w/ Magnaflow straight thru canister and maybe updating the downpipe w/ aftermarket down the road.
Anyone done just the muffer change?
thx
Old Jul 26, 2004 | 01:54 PM
siantjab's Avatar
I had a BR muffler delete pipe for a while and loved it. Nice sound, not loud at all, very nice rumble. Don't even bother with a muffler; it's not worth it on the stock sys. If you're gonna take it off just use a muffler delete pipe and call it a day. You can find them used for under $100 on this site.
Old Jul 26, 2004 | 02:06 PM
spyderx's Avatar
Good Idea, thx!
So how's your catback compare to the muffler delete pipe?
Old Jul 27, 2004 | 12:49 PM
berkel's Avatar
I have a Buschur AB.
I actually ordered the muffler delete and they sent me the AB by mistake...
Anyway, the stock muffler is quite restrictive, and the straight through muffler did make a noticeable "sotp" difference...
I have since added a 3" Helix DP and 3" RT cat, and I will replace the AB, but it does add perf without too much noise or cost. However, I would go full 3" if you can.
FB
Old Jul 27, 2004 | 06:20 PM
Jonasan50's Avatar
One thing that I've seen is the Pruven Performance axel-back.. Basically it's a straight thru replacement for the stock muffler.. It looks really good on the car and supposedly helps too! Really nice canister... My .02
Old Jul 30, 2004 | 11:48 PM
oguratevo's Avatar
Try getting stealthworks rear muffler, uses the same stock evo rear muffler, but internals were modified. $199 with core charge(your stock muffler) worksrally.com
Old Jul 31, 2004 | 04:58 AM
4G63 Power's Avatar
I was considering this too. How big is the stock exhaust piping again? sorry I dont feel like crawling under the car right now and getting dirty. thanks
Old Aug 1, 2004 | 11:28 AM
bluebanana23's Avatar
2.5 inches
Old Aug 1, 2004 | 03:48 PM
g6civcx's Avatar
The Buschur muffler delete is just a 2.5" straight pipe and a 3.5" tip. That **** is mad loud
If you want to get a downpipe later on, the Buschur may not fit an aftermarket pipe unless it bolts up just like a stock pipe.
The stock muffler is a heavy piece of ****, about 19.5 pounds. The delete pipe only weighs 3.5 pounds.
justboosted02
Northeast Region
Oct 6, 2008 01:08 PM
silverstream
Oct 23, 2006 07:44 AM
KOEvo
Apr 5, 2006 03:01 PM
eericcc2
Lancer Engine Tech
Feb 17, 2005 02:13 PM
initialD
Dec 11, 2003 05:08 AM
