Engine braking helps turbine cooling?
Old Aug 27, 2004 | 09:05 AM
os2's Avatar
os2
I had just installed my EGT gauge (d-series 2-nd cylinder 5" from the block) and was observing temperature drops from 1400F down to 700F while engine braking.
I have a habit to revmatch and downshift 4->3->2 while coming to a stop, so I saw temperature dropping consistently. Is it some sort of a "ventilation effect"?
At idle and at least for a 30sec. after I shut off the engine needle stays at 1000F
Old Aug 27, 2004 | 09:12 AM
mifesto's Avatar
wait 1400F? isnt that abit high?
Old Aug 27, 2004 | 09:19 AM
MalibuJack's Avatar
I think most people use gauges that read in Celcius, not Fahrenheit.. 1400F is about 760C
Makes perfect sense, your not pumping burning gases on deceleration.. the ECU seems to cut fuel on decel so your basically pumping air through the turbine..
4G63>OOOO's Avatar
Agh, that's too cool, nothing interesting happens until 950C.
BOOM!
Old Aug 27, 2004 | 09:21 AM
mifesto's Avatar
oh i always thought the typical EGT reading for our car is around 800F...
