Installing shift light, where is tach signal wire and mounting suggestions?
Old Sep 8, 2004 | 10:47 AM
EvoSam's Avatar
I got my new shift light and was planning an install soon, but can anyone tell me where the tach signal wire is? I've heard it's wire #58 but that really means nothing to me.
Also, I like to do stealth mounts, has anyone dug into their AC ducts in the center of the dash? If so, how hard are they to get to and how much junk is in the way? In my corvette I had it in there ala this: http://www.grandsportregistry.com/te...ght/index.html
Thanks for the help,
Sam
Old Sep 8, 2004 | 11:27 AM
Crazy4Cars's Avatar
http://www.roadraceengineering.com/e...-ecuwiring.htm
PIN# 58
Old Sep 8, 2004 | 09:52 PM
ASTROEVO's Avatar
like to see what your install looks like afterwards....
Old Sep 9, 2004 | 06:39 AM
leonard_shelby's Avatar
curious if it works, I have a small shift light that pin 58 or the pin for the crank position senson fail to work, maybe its the shift light, going to try the tach wire from the cluster.
Old Sep 9, 2004 | 07:30 AM
Ev0 1's Avatar
I'm interested in this Mod, please keep us updated on it.
Old Sep 9, 2004 | 07:44 AM
bolsen's Avatar
I'd like to run a shift light. But if I did, I'd like to do a pencil tip sized light. Something small in invisable, but then I can pay attention to road vs my tach.
Old Sep 9, 2004 | 07:59 PM
EvoSam's Avatar
I've been using shift lights for years now, After my first one I came to really rely on them to keep my eyes on the road at all times. I pulled my dash apart today to check on fitment, I'll do the actual install soon and post on it. First I'll have to check that tach signal wire it sounds like.
Thanks,
Sam
Old Sep 10, 2004 | 10:33 PM
ASTROEVO's Avatar
hey get this install done already i wanna go out tomorrow and copy your idea...
Old Sep 11, 2004 | 12:30 AM
EvoSam's Avatar
Sorry, been real busy with work and this weekend is probably going to be just as busy if the weather is nice enough to take the boat out. For sure I'll get it done within the week, I have everything I need and first I have to check that tach signal wire that Leonard Shelby said didn't work for him.
Sam
Old Sep 12, 2004 | 01:02 PM
ASTROEVO's Avatar
Well Ok Then I Forgive You.....but Still Interested In Copying Your Install....ha
Old Sep 12, 2004 | 01:29 PM
I think when I try again, I'm just going to tap the rpm wire from the cluster, I tried both ECU pins / wires and had NO luck.
Old Sep 12, 2004 | 07:36 PM
EvoSam's Avatar
Which wire in the cluster is it?
Old Sep 13, 2004 | 12:18 AM
deekay247's Avatar
!!!!Upload PICs!!!! when your done.
Old Sep 13, 2004 | 10:10 AM
EvoSam's Avatar
I'll upload pics, just have to figure out how or where I can host them. Is the tach signal wire in the cluster that leonard_shelby is referring to the same one that turbo timer's use? If so, I know exactly where that is and it'll be easier to tap than off the ECU.
Old Sep 13, 2004 | 08:18 PM
EvilBlueEvo8's Avatar
im interested in this as well
