EVO 8 & EVO 7 performance parts combatibility?
Old Sep 9, 2004 | 08:21 PM
sloweclipse's Avatar
EVO 8 & EVO 7 performance parts compatibility?
Fellas I have an LHD EVO 7 which I believe is the international spec.
Anyways I am ordering all the parts available from APS for the US spec EVO 8 and I would like to know if I will have any trouble fitting them on my EVO 7.
here are the parts.
3.5 Turbo Back
Front Mount Intercooler with complete piping, turbo to throttle.
Cold Air intake
Water Sprayer resevoir
Dual Vent BOV
Dual Ball Bearing turbo Kit
Intake Manifold
Here is a link,
http://www.airpowersystems.com.au/us_spec/evo/evo.htm
Old Sep 9, 2004 | 10:38 PM
evo sky's Avatar
all the parts are interchangable except for the exhaust; it might not match ur rear bumper properly if it was built for a USDM evo VIII... other than that everything else should be a direct fit
good luck
Old Sep 9, 2004 | 10:44 PM
budlong's Avatar
i am selling an evo 7 hks hi power cat back exhaust for cheap..
please pm me if you are interested..
BUDLoNG
Old Sep 10, 2004 | 02:33 PM
thanks for the replies.
so the intercooler should be fine?
and about the exhaust, do you mean that the exit on the bumper might be on the other side? or the actual bumper being a bit different that the tip or muffler might rub?
Old Sep 10, 2004 | 08:27 PM
evo sky's Avatar
the JDM bumper (or evo 7 bumper) is shorter than the USDM one (the exit is on the same side, dont worry)
so if an exhaust system is made to fit the USDM bumper, it will stick out "too much" for an evo7
the fmic should be fine; people had been swapping evo 7 front bumper on evo 8's with no modifications... it should be a direct fit
Old Sep 10, 2004 | 11:42 PM
MaxR's Avatar
according to z1auto.com, RA intercooler piping for jdm spec cars require some modifications to fit us spec so it might be the same if you try and fit us spec intercooler pipes to a international spec evo.
Dross99_si
Evo X Dyno Results
37
Jan 17, 2018 01:06 PM
James@HKSUSA
HKS
Mar 4, 2016 11:02 AM
lancerCANADA
Canadian Forum
Jul 11, 2007 01:35 PM
Nathan04'EVOVII
33
Sep 12, 2005 10:23 AM
RallySport Direct
148
May 10, 2005 09:39 AM
