Top speed in each gear?
Old Sep 18, 2004 | 03:22 PM
EvilBlueEvo8's Avatar
Does anyone know the top speed in each gear if you shift at redline (7k rpms)?
1st: 30 mph
2nd: 59 mph
3rd: 83 mph?
4th: 110 mph?
5th: 157 mph?
Old Sep 18, 2004 | 03:55 PM
PVD04's Avatar
Those seem pretty close to what I remember them being while driving, although I've never gone that high in 5th.
Old Sep 18, 2004 | 03:58 PM
vegasboy301's Avatar
from what ive heard/exprierienced 4th goes to 120
Old Sep 18, 2004 | 04:44 PM
areet's Avatar
4th redlined is 120, 5th at 6800rpm or so is 156
Old Sep 18, 2004 | 08:29 PM
JaguarS4R's Avatar
This will show yu excatly what speed each gear goes to:
5th v.s. 6th
https://www.evolutionm.net/forums/at...chmentid=41399
Old Sep 18, 2004 | 08:33 PM
XRS-Lift's Avatar
5th v.s. 6th
thats a lot closer to what i was thinking. I knew 1st was into 4 mph, 2nd over 60 mph and 3rd at 90 mph, 4th at 120 5th i never toped out in.
ASTROEVO's Avatar
so.....these are all stock specs?
Old Sep 18, 2004 | 08:38 PM
PVD04's Avatar
these will vary depending on whether you are talking about redline (7000) or fuel cut (75-7600). And yes, these are all stock specs.
Old Sep 18, 2004 | 08:40 PM
XLR8R's Avatar
Well, unless you get a chip that up's the fuel cut, change the tranny, or change the diffs, no amount of mods will affect the top speeds in each gear
Old Sep 18, 2004 | 08:52 PM
ASTROEVO's Avatar
not true.....i have several mods and a apexi power fc ....which resulted in a much higher top speed in 5th gear...
Old Sep 18, 2004 | 08:59 PM
1QWKEVO's Avatar
I would have to disagree as well, airflow over the car plays a major role as well as HP when these two are looked at together... more drag needs more HP to make the same topspeed and less drag requires less HP.. also tire size will affect the topspeed of your vehicle... just going from 235 to 245 will add at least 5mph
Old Sep 18, 2004 | 09:03 PM
ASTROEVO's Avatar
i am building my car for top speed....so i have gone around and around about this subject....i am about to install the hks final drive 4.11...so i can be geared for 200mph...
Old Sep 18, 2004 | 09:09 PM
2k4EvoVIII's Avatar
Where and how much did you find this gear?
Thanx
Chris
Old Sep 18, 2004 | 09:16 PM
Madwheel's Avatar
I'm thinking he may mean the physical limitation of the car, due to the gearing and redline. Assuming the car has 600hp or 2000hp (never happening but...), if the gears are the same, as well as the rev limiter/fuel cut, then it'll still hit the 174 mark.
If you change your final drive, 5th gear, or rev limiter, then your top speed will have a higher LIMIT. But if you don't make the power to over come the drag (IE) then it doesn't matter what gears or rev limit increase you have. My 2 cents..
Old Sep 18, 2004 | 09:25 PM
ASTROEVO's Avatar
Thanx
Chris
well heres the deal......the hks kansai service final drive 4.11 runs about $800.00 ..... but the good news is the that another member on this board hookt me up with som info....the ratio of the 2000 mitsubishi GALANT is the ratio of 4.111 of the evo and it fits exactly into the tranny....and the part from mitsu is only about 200.00
