downshift frm 5th to 3rd
Old Sep 21, 2004 | 02:58 PM
  #31
6one9EVO's Avatar
thanks for the posts guys.....now that i have a pretty good idea on what to do im gonna try it out today! HAH!
Old Sep 22, 2004 | 01:24 PM
  #32
[TYPE]SS's Avatar
Originally Posted by twinevo
I think I get it now, so if your car is normally at 4500 RPM at 3rd gear going 55mph than you would blip the throttle to around 4500 RPM before releasing the clutch when downshifting from 5th(while at 55mph) to 3rd. Does this sound correct?
that's exactly it. i haven't really tried from 5th to 3rd, but i do it on every 1gear lower
downshift. do it everyday and u should get used to it very quickly. it gets very
smooth enough that friend next to you wont even noticed u downshifted~
Old Sep 22, 2004 | 01:27 PM
  #33
twinevo's Avatar
I've started to practice. It's a lot harder than it sounds. just have to keep trying. So, do you tap the throttle as you are releasing the clutch or is it more delayed?
Old Sep 22, 2004 | 03:33 PM
  #34
evo sky's Avatar
the idea is to allow the engine to be in the desired rpm range before it engages the lower gear. therefore, it is not "more delayed". As you step on the clutch, the car is in neutral (easiest gear to rev); do not delay, because the rpm will drop as soon as it is in neutral. Instead, rev it up with the gas pedal to the correct rpm for the intended gear. shift into that gear while you are still on the clutch. When that process is done, release your left foot from the clutch, hit the gas, and voila =) pratice this on a straight road for acceleration until the motion is not jerky... and as you get smoother, try to downshift before approaching turns.. good luck
Old Sep 22, 2004 | 03:40 PM
  #35
twinevo's Avatar
thanks sky, i'll give it a try.
RalliartMY10
Apr 28, 2024 10:30 AM
millsyy17
17
Sep 5, 2011 12:22 PM
pb91
Jun 8, 2011 02:44 PM
Derek888
Mar 19, 2005 09:34 AM
jeddi
Aug 12, 2004 02:32 AM
