Customizations that don't jeopardise warranty
Old Sep 21, 2004 | 08:36 PM
g6civcx's Avatar
What customization or modification can you think of that will not risk getting the warranty voided?
My thoughts:
  • New radio/head unit
  • Regular speakers, not subs/amps
  • Window tints
  • Debadging
Old Sep 21, 2004 | 09:39 PM
SinCityEvo's Avatar
Stickers?
Old Sep 21, 2004 | 09:41 PM
bluebanana23's Avatar
s2000 antannae
Old Sep 21, 2004 | 09:56 PM
JaguarS4R's Avatar
exhuast and probably BOV, especially exhuast, not sure about BOV, but it wouldnt effect anything
Old Sep 22, 2004 | 03:16 PM
evo sky's Avatar
ummm wheels?
interior trims
seats
Old Sep 22, 2004 | 03:25 PM
hbruce16's Avatar
BOV voides the warrenty...not sure if you change to the MR BOV...will let you know. New air intakes don't void it either as long as their CARB certifyed...
jasonc32amg's Avatar
BOV is a waste of money...
exhaust would be safe if you keep the cat...
Old Sep 22, 2004 | 03:37 PM
evo sky's Avatar
hbruce: intake is not a warranty-safe mod... if it is carb certified, you wont get in trouble with the cops, but dealerships can still deny warranty for two reasons; 1.) they will no longer service air cleaner component (you have to change/wash your own filter)
2.) if the engine ever hydrolock, they will point straight to the open air filter element and blame it on that
Old Sep 22, 2004 | 03:42 PM
twinevo's Avatar
i've read that exhaust even with the cat will void warranty. does it depend on the dealer?
Old Sep 22, 2004 | 03:48 PM
evo sky's Avatar
as long as the it has the factory cat, its hard for the dealerships to blame anything on just an aftermarket exhaust system, and therefore, caback exhausts are generally a safe mod
Old Sep 22, 2004 | 04:00 PM
tokeone's Avatar
i asked my local dealer when i purchased the car if i could get away with exhaust and intake
he said anything that wouldnt give me serious increase in HP would be fine and that most warranty voiding they have had to do involved powertrain because of clutch upgrades.
but from what ive read the only thing id even consider leaving on the car is my exhaust if i ever took it back to them.
ive even gone through the trouble of getting replacments of any clamps/bolts/screws that ive done any wear to.
Old Sep 22, 2004 | 05:39 PM
twinevo's Avatar
ok, how bout a full turbo back with a high flow cat?
Old Sep 22, 2004 | 06:02 PM
donour's Avatar
Gauges.
Old Sep 22, 2004 | 07:39 PM
g6civcx's Avatar
Stickers = paint warranty issues
Antenna should be okay.
Exhaust = definite powertrain warranty issues. Less backpressure = lean. Definitely will have issues if you swap out the cat. Swapping out a normally functioning cat is also illegal. Federal law.
BOV = definite powertrain warranty issues
Wheels = should be okay, unless it created clearance problems or something
Interior trim = should be okay if it's not mechanical or electrical
Seats = I believe it shouldn't be a problem. You may have safety issues though.
Intake = powertrain warranty issues.
Gauges = depends. If you get a boost/vacuum leak, your warranty will have issues.
And again it really depends on the dealer, but I'm trying to cut down to the lowest common denominator.
Old Sep 23, 2004 | 07:58 AM
DaWorstPlaya's Avatar
What he said .... well put
