2500-2600 lbs with full interior !
Im on mission to get my 2003 gsr evo 8 on a big diet . my goal is to get the car down to 2500-2600 lbs with out me in it while retaining full interior appearance , factory brembos and power steering. Do you guys think is possible ?
this is what i've done so far including light weight parts. my car is getting the short block built so i can't drive it to the scale yet and I'm so anxious to know more or less how much it's going to weight. 1. Front and Rear crash beams removed 2. Ac system removed including the heater and all the crap behind the dash . 3. crash bar behind the dash modified by removing all the unnecessary brackets. 4. metal brackets behind the kick panel removed 5.sound deadening removed 6.carpet padding removed and windshield washer tank and hose 7.All seat belts removed except driver side . ALL airbags removed 8. removed all connectors from wiring harness that i don't use ,rear speakers removed 9. metal tube lines under the car removed 10. canister and egr system removed 11. Buschur mustache bar and brackets 12. Buschur front crossmember bar 13.torque solution mounts 14. EVO rs case 15.carbon driveshaft 16. stm d2 coilovers 17. giro disc light rotors front and rear 18. aluminum lug nuts 18. wedsports tc105n 19.removed engine bay fire wall padding also removed the one behind dash . 2-.gutted trunk 21. side exit exhaust 22. 2 front nrg carbon seats 23. org steering wheel with billet hub no airbags 24.front bumper has all removed metal bracket in the back not all but some . 25. abs system removed with the stm delete kit. 26. power steering coolant lines removed goes straight to rack , 27. lithium small battery kit with stm tray . 28 removed steering column plastic Metal Insert 29. brake shields removed 30. no wing 31. koyo half size radiator with fan |
That is a very tall order. My car in almost the same trim as yours is 2800lbs wet. To cut 200lbs more would be a mission. For me the only stuff left to do is cf trunk, plexiglass windows, tubular front sub frame. But all that might only shave another 50-80lbs. Also switch to a fuel cell.
My thread https://www.evolutionm.net/forums/pr...l#post11668152 |
I've read the thread where stm rs with full interior ,brembos and ac weights in at 2700lbs . im here scratching my head :confused: . your car is 2800LBS with you in it.
Originally Posted by TheBoz
(Post 11676338)
Did you cut out the inside of your door panels? I know some people do that.
Front and rear wipers and motors? The metal exhaust heat shields? |
Originally Posted by Dragking2189
(Post 11676383)
My car is 2804 with out me, and 3/4 tank of E85. I am also running a full size optima battery, and ACD, steel trunk and oem wing. So how STM got to 2700lbs is amazing to me. They must have some black magic going on. So I could see getting down into the 2700 even range, with ACD Removal, CF Trunk no wing, small battery, fuel cell, half radiator, front tubular sub frame, rear sub frame. |
aluminum/carbon fiber roof?
I didn't cut inside on the door . Rear wiper is completely removed I have a rs back glass. all heat shields gone .
Originally Posted by DSMolition
(Post 11676491)
the optima battery will save you like 28 lbs if you replace with a small lithium , acd removal will save you like 14 lbs including the brackets , the acd tcase weights like 12 lbs more than the rs tcase. Emery from stm posted a pic in his STREET rs with brembos,ac and full interior right at 2700 lbs . How he did it ? I have no clue.
(Post 11676532)
