Help! I need to know how to remove door panel?
Old Oct 7, 2004 | 03:11 AM
x7eVoLuTiOn7x's Avatar
Cant seem to be able to remove my door panel. The door opener broke, the only way i can open the door now is from the outside. Pls. help!! its been several months, i cant stand it anymore!!!!
How many screws are there to remove? i only saw 3.
Old Oct 7, 2004 | 10:26 AM
LancerEvoMR's Avatar
Moving to Evo How To Questions.
Old Oct 7, 2004 | 10:33 AM
EvolutioNiK07's Avatar
I wish i had a pic to show u where all the screws are, but there should be one screw behind the plastic that covers the mirror, one in the door handrest pocket, and another one behind the plastic in the door handle that you have to remove. I used an exacto knife to wedge the plastic out, but anything thats very flat will work. Once you removed those screws, you'll have to wiggle out the door handle, just play with it a bit and it should come out. There's also a couple of screws covered by a plastic button on the edge of the door. Once u removed those your now your ready to pull off the door. Good luck.
Old Oct 10, 2004 | 11:39 AM
Murdock's Avatar
i'm having the same problem except i'm the lucky soul who also has to contend now with the roll up window handle being as how i drive an RS model with no power windows. Does anyone know how to remove the window knob from the door panel???????? Can you just twist if off or do you have to remove a cover or what.
Old Oct 10, 2004 | 11:46 AM
Kelmar's Avatar
Murdock
Here ya go! https://www.evolutionm.net/forums/sh...ad.php?t=94787
devilsfutbol17
Jun 20, 2017 08:28 PM
fatih
Lancer Troubleshooting
Mar 10, 2017 01:20 AM
bowlofturtle
20
Nov 2, 2009 03:48 PM
Evo Girlie
Sep 15, 2006 06:21 AM
yellowman
Jun 4, 2004 06:42 PM
