Using a Fuel Pressure Regulator for Injectors and Pump??
Old Nov 2, 2004 | 06:09 AM
EvoRs's Avatar
I have to drive 300 miles to get a flash done on my car.. Im replacing my injectors and upgrading since the stocks ones are leaking pressure slightly, ive also bought a walbro pump. Now if i just put these in, my car will run like crap if even run.. I was told that if I installed a Fuel Pressure regulator and adjusted it, i could get away with driving my car for the 300 miles and it would allow me to run somewhat.. Is this true..?
Old Nov 2, 2004 | 08:22 AM
EvoRs's Avatar
Anyone?
Old Nov 2, 2004 | 08:26 AM
2003evolution's Avatar
well i got fpr in my evo. with walbro pump and 660cc inj in it. this week its gonna flash, tune, dyno. will update u if its does help.
Old Nov 2, 2004 | 08:44 AM
EvoRs's Avatar
Im just curious if i can adjust it to allow me to run my car to get the flash.. Otherwise i have to install the stuff at the flash place..and i could run into issues doing that...
I noticed lancershop bolt on fuel pressure regulator is out of stock.. Where else can i get one?
Old Nov 2, 2004 | 08:46 AM
gofaster87's Avatar
You can just use the an aeromotive fpr and set up the fittings yourself. You have to also purchase the fuel rail adapter that allows use of the AN fittings.
Old Nov 2, 2004 | 08:52 AM
M3lachsilber's Avatar
choad
Moving to Evo How To's..
Good luck!!
clip14
Jul 2, 2015 05:49 PM
Liqquid
10
Aug 13, 2013 07:07 AM
m7mad.a
Mar 4, 2012 05:33 AM
oZuser
Lancer Troubleshooting
Apr 23, 2010 08:22 AM
Scud!
May 16, 2004 04:42 AM
