Black Out Headlight Materials
Old Nov 6, 2004 | 06:06 PM
BlackLancer2k2's Avatar
that clear silicone will be fine...
and i used flat black when i painted my headlights, it turned out great
Old Nov 6, 2004 | 06:15 PM
EVO MR FU's Avatar
to sand or not too sand....so ur sayin if I use black primer I dont have to sand, but if I use gray then I should sand? I dont want like bubbles under my paint as evodave mentioned.
if I do sand I guess I need some 600 instead of 400
Old Nov 6, 2004 | 06:33 PM
AltezzaBob's Avatar
anyone have pictures of how they turned out?
Old Nov 6, 2004 | 06:36 PM
plokivos's Avatar
I like the oven method. It's better than using dremel like in that video to pry the headlight open.
That's how we used to do with prelude headlights.
Old Nov 6, 2004 | 06:40 PM
AltezzaBob's Avatar
if you have a diamond dremel bit, you can dremel it off without causing heat and shaving only a bit of the plastic off.
BADEVO's Avatar
OH hell no.. dont dremel the headlights. Thats for the tail lights only as they are sealed in 2 different ways.
Old Nov 6, 2004 | 06:43 PM
EVO MR FU's Avatar
Hot glue gun works for headlight correct? Im a little spectical about putting it in the oven
Old Nov 6, 2004 | 06:56 PM
plokivos's Avatar
it's silicone chaulk
Old Nov 6, 2004 | 08:50 PM
BADEVO's Avatar
if not the oven, heat gun. The adhesive they use on the headlights is heat sensetive.
Old Nov 8, 2004 | 03:11 PM
James's Avatar
ok so a heat gun, so how long again do i need to have the head lights in the oven if i do it that way. i just want to do it this weekend.
thanks guys
james
Old Nov 8, 2004 | 03:24 PM
drmosh's Avatar
no need to sand, just primer and paint...
I have done a few evo headlights already...
oven takes too long and has potential for problems... get a friend, heat gun, screw driver, heat the seals, pry apart... primer, paint, reseal with the existing glue... best chance for good seal...
Old Nov 8, 2004 | 03:27 PM
James's Avatar
thanks man, but reuse the existing glue how? I don't mean to sound like a dumb A$$ but i fon't want to mess up.
James
Old Nov 8, 2004 | 04:07 PM
EVO MR FU's Avatar
FINALLY freakin finished longest job evaaaa be prepared
Old Nov 8, 2004 | 05:37 PM
RLLN247's Avatar
looks good ! Did you use the silicone or the hot glue to seal it back up ?
Old Nov 8, 2004 | 06:47 PM
EVO MR FU's Avatar
I used silicon for window & door, and blow dryer instead of heat gun
