Disable A/C on with Defrost?
Old Nov 16, 2004 | 04:34 PM
JT_EVO8's Avatar
Greetings all,
Does anyone know how to prevent the A/C from coming on when in Defrost mode?
Thanks for any input.
JT
03 Evo 8
Old Nov 16, 2004 | 04:38 PM
dizzigital's Avatar
Originally Posted by JT_EVO8
Greetings all,
JT
03 Evo 8
hmmm.... take it out of MAX A/C...?
Old Nov 16, 2004 | 04:42 PM
MYEVOVIII's Avatar
I dont think he has it on. My Evo also does it when I turn on my rear defroster seems like it turns on the compressor to my A/C.
dizzigital's Avatar
and/or push the A/C button
Old Nov 16, 2004 | 04:43 PM
dizzigital's Avatar
hmmm... really? i never noticed that...
Old Nov 16, 2004 | 04:49 PM
Alchemist's Avatar
the defrosters are supposed to run the air over the AC compressor to help dry the air and defog the windows faster. You can speed up the process slightly if you turn the AC on with the defroster on. You'd have to disable the AC compressor to stop the defroster from using the pump.... at least I don't think there's another way to make it not use the AC.
Old Nov 16, 2004 | 05:33 PM
JT_EVO8's Avatar
That sucks. On my old Neon it was a very simple process to permanently disable this "feature."
Thanks.
JT
Old Nov 16, 2004 | 05:59 PM
Alchemist's Avatar
I'm not 100% sure, but that's what I've been told. How did you disable it on the neon?
Old Nov 16, 2004 | 06:37 PM
JT_EVO8's Avatar
In the HVAC panel there was a connection made when you turned the knob to Defrost mode. All you had to do was prevent that connection (basically cut a trace on the board) from being made and the air flowed like it should in Defrost mode but the AC didnt kick in. It was much easier than it sounds...
Thanks.
JT
CharliEvo8
Jan 5, 2025 10:14 AM
eTiLiKo
May 23, 2012 05:45 AM
fkw958
Feb 6, 2008 11:09 AM
Evasive EVO
Dec 26, 2007 11:44 PM
snoop
Feb 27, 2007 07:41 AM
