Question on Sparco 4-pt Harness Install
Old Jan 12, 2005 | 06:21 PM
RaVnWaZn's Avatar
Question Question on Sparco 4-pt Harness Install
i just bought a sparco harness bar and 2 sets of 4 point harnesses to go with it. 48" shoulder belts and 36" lap belts. The harness bar is installed and the shoulder belts are rigged, now the only problem is installing the lap belts. I have hardware that's obviously for the lap belts, and i'm just kinda wondering where i should anchor the lap belts. is there drilling required? is there somewhere where they bolt into with the hardware? if anyone has done this before with the harness bar and could help out that'd be greatly appreciated. thanks!
Old Jan 12, 2005 | 06:25 PM
skiracer's Avatar
I don't have the harness bar, but my lapbelts are mounted where the OEM anchor points are. You need to take out the center console to access the middle seat belt anchor points. To remove the center console, just take out the 2 screws inside the armrest.
Old Jan 13, 2005 | 03:58 PM
RaVnWaZn's Avatar
ahhh, thanks. now, as far as the outside mounting points are concerned, should i just bolt em in at the base of the B-pillar where the stock seatbelt mount is? (that's the same place where the bottom of my triangulation bar for the harness bar was bolted in)
Old Jan 14, 2005 | 06:27 AM
skiracer's Avatar
Call Sparco and they'll be more than happy to help ya out and/or check out sparco's website.
David Buschur
Jun 24, 2014 01:16 PM
tmaddox
Aug 10, 2011 08:03 AM
vtluu
16
Jan 8, 2011 07:57 AM
KevinD
Mar 1, 2005 09:46 AM
kingkyle
Jan 10, 2005 01:56 AM
