What did I remove? PICS included HELP!
Old Feb 9, 2005 | 12:47 PM
mr0072003's Avatar
HI team I just installed my 3' Downpipe but I think thet lower sway bar or somthingwas in the way. I removed it, but I am so worried that it is a critical part of the car. Here are pics of my and my roomate trying to install the downpipe and the bars being in the way. ONly one was removed, the other had to be in order to get it to fit. IS there another after market part, or did I install the downpipe wrong.
that is as far is I could get the bar to get to where it needed to be.
Thats not me that is my roomate . BUT that is the downpipe in the way. I dont think the heat wrap was thick enough to be the culprit, but if anyone knows please help.....I am so worried right now....BUT THE CAR HAULS ars.....
Old Feb 9, 2005 | 12:49 PM
bluebanana23's Avatar
those are the braces to keep the chasis more stable under hard acceleration
Old Feb 9, 2005 | 12:51 PM
redevo561's Avatar
You need to put spacers in it so the downpipe can clear especially if you have heat wrap on the downpipe take care bud
Old Feb 9, 2005 | 02:09 PM
mr0072003's Avatar
So it os ok to have spacers, it will not harm handling? Currently it is off the car, is it safe? I really appreciat the input too guys. Also would you recommmond anything.
egui42's Avatar
Tie bars, just go to home depot and get some spacers, and maybe some longer bolts. The bolt size are Metric, M1.25, I think. Correct me if I'm wrong, please.
Old Feb 9, 2005 | 03:14 PM
mr0072003's Avatar
Man you guys are great...I swear without EVOM I would be spending some cash...I wish I could by you a Beer or Somthing....I wll Check it today and see what I can Find.
Old Feb 9, 2005 | 05:32 PM
jonduke's Avatar
the same thing happened to me when i installed mine,i just put two washers in each bolt location to space it from the chassis-then when my suspension was getting done by RRE he just took this tool that punched the tie bar down to clear
Old Feb 9, 2005 | 05:35 PM
asasin79's Avatar
if that is the ultimate racing dp you don't need to put spacers
Old Feb 9, 2005 | 05:39 PM
tokeone's Avatar
or you could just hang out with us TO guys and all your troubles would be solved
but NOOOOOOO petes too cool for us.
Old Feb 10, 2005 | 12:09 AM
mr0072003's Avatar
PM toke....
Old Feb 10, 2005 | 12:13 AM
Jakeg97's Avatar
i could go for a beer right now..
Old Feb 10, 2005 | 12:19 AM
Deca Auto's Avatar
Yeah the bolts are at home depot. You need them to be about 20mm longer. I also recommend buying thick nuts instead of using a lot of spacers. Its cheaper and easier.
Old Feb 10, 2005 | 12:39 AM
mr0072003's Avatar
Thanks Deca....thats sounds like a good idea.....I think I will.
Old Feb 10, 2005 | 09:10 AM
sleet's Avatar
Did you heatwrap that yourself? How'd you do that?
mr0072003
Jun 9, 2007 08:47 PM
mr0072003
Dec 29, 2006 11:59 AM
white venom
Aug 12, 2006 11:12 PM
mr0072003
Jun 12, 2005 09:34 PM
OZLancerlunatic
Feb 17, 2005 02:11 AM
