Blacked out Tail lights..
Old Feb 17, 2005 | 11:27 AM
SlowboyMR's Avatar
Well.. since there was a thread about how to black out your headlights instead of paying $800 for the JDM MR ones.. I figured why spend $400 on the JDM tail lights right? SO the process is identical to the headlight directions. Bake at the same temp, use a friend (be careful if they are holding the housing for you not to squeeze directly on the lense i know it may bow in). You dont need high temp paint. i used a standard Krylon Primer and Ultra Flat Black. The only difference i like is you keep the clear corner lense instead of the amber of the MRs.
Search on here for the post "Headlight Blackout" By Aaron Pursell
Now these are glued with a type of Epoxy, so the heat helps, but they are unable to be reglued by putting them back into the oven. I used an Epoxy lense repair which dries clear.
the tear down is time consumming 1.5-2hrs for both, reassembly was a cake. Just be clean about it for the best look. here are some pics.
Thanks
Mark
SBR
Attached Thumbnails Blacked out Tail lights..-dsc00159-small-.jpg   Blacked out Tail lights..-dsc00161-small-.jpg   Blacked out Tail lights..-dsc00163-small-.jpg   Blacked out Tail lights..-dsc00170-small-.jpg
Old Nov 1, 2007 | 03:34 PM
SPOOLD's Avatar
you were able to get the lenses off without any cutting? what temp and amount of time were you heating the housings at?
Old Nov 1, 2007 | 07:57 PM
SlowboyMR's Avatar
As I stated in the original post. Follow the directions for the headlamps. I had to still use a knife to cut the lense adhesive, but you have to do the same on the headlamps. Its tedious, and you have to be careful. I put them in and out of the oven a couple of times. But they turned out nice I think.
Old Nov 2, 2007 | 07:36 AM
SPOOLD's Avatar
yeah they did. thats awesome. i've been aprehensive with some people using a dremel to separate the tails. i'm definitely gonna try this one of these weekends now
Old Nov 2, 2007 | 07:45 AM
MDUBS's Avatar
I noticed that you did a long time ago. Any problems with water or moisture in the lens after you were finished? I have a buddy that did it to two of his Sub's and they both turned out nice.
Old Nov 2, 2007 | 12:17 PM
SBR INC's Avatar
HOLY BACK FROM THE DEAD -
He drives an AUDI now - bahwhaaaaaaaaa
LOL
Hi Mark -
Mike Huml
Slowboy
Old Nov 16, 2007 | 01:26 PM
ohEVO18's Avatar
ok i have what may seem to be a stupid question, but is there anything you have to do to get the tails out of the car other than removing the trunk liner and unscrewing everything? Just wanna know before I get into it, I already have everything I need. Thanks all in advance
Old Nov 16, 2007 | 01:30 PM
SICK SPEED's Avatar
Nice clean job man - looks sweet - nice low buck mod that makes you ride stand out!
Old Dec 9, 2007 | 04:20 PM
ohEVO18's Avatar
i tried this and failed miserably..thanks to my buddy breaking my lens
Old Dec 22, 2007 | 02:45 PM
PedroMartinez's Avatar
doesnt evodave do this?
Old Feb 1, 2008 | 02:22 AM
EvoKnievo's Avatar
yeah for a nice chunk of $$$$
this cost's like 10 bux said and done
Old Feb 3, 2008 | 01:11 PM
SlowboyMR's Avatar
As Mr. Huml (Hi Mike!) stated above I do drive an Audi now. I did have the car for over a year after that mod and the lenses still looked great. I actually swapped them off the car before i go rid of it with a stock set and sold the modded ones afterwards!
Commenting on the above disaster, yes, it is a chance you take, as is any do it yourself mod really. Headlights are real scary especially when you look at the price of those. But these DIY info stories arent for the faint hearted and you have to have faith you can pull it off (including your friend, choose wisely!), or I wouldn't recommend doing it. I will admit I was nervous and was until finished!
Evo dave wants alot, I knew I could buy a used stock set if I screwed mine up and took the chance. Good luck to the rest of you that try it!
Mark
Old Feb 5, 2008 | 11:18 PM
gtr_rider's Avatar
its not that difficult to do this if you use an oven and have a lot of patience.
Old Mar 24, 2008 | 12:08 AM
Daswtasn4u's Avatar
Has anyone done the taillight housing in White instead of Black??? Pics???
rogerlam
Sep 13, 2016 06:01 AM
Frew
Jul 13, 2014 11:14 PM
SSickLS1
Oct 7, 2013 12:08 PM
Kada__85
Jul 26, 2013 06:12 PM
brakedrift1217
Apr 1, 2013 08:35 PM
