HELP on Greddy TT Please!
Old Mar 5, 2005 | 12:59 PM
tke_413's Avatar
I found it once (when I didn't need it) but can't find it again!! Does anybody know what wires in the harness are supposed to be switched to get rid of the "hick-up?" Also, how do you get them out of the plug?
Old Mar 5, 2005 | 01:06 PM
evo_whiplash's Avatar
Sorry for OT but, what "hick-up"?
Old Mar 5, 2005 | 01:08 PM
denial's Avatar
switch the green and the blue wire on the 3 wire harness (the one that plugs into the separate vehicle specific ignition harness). don't touch the red wire.
Old Mar 5, 2005 | 01:10 PM
tke_413's Avatar
STAY AWAY FROM THE RED.....gotcha!!!!
Old Mar 5, 2005 | 01:11 PM
denial's Avatar
oh, in order to get the wires out of the harness you need a small sharp/long object. I used a "poker" that came with a small screw driver set. unplug the harness and look at the prongs. next to each prong there should be a little metal tab. use the poker to push the tab down, and then use a pair of needle nose pliers to grab the main prong and push out the entire wire. it sounds more complicated here, but it's really easy when you're actually doing it.
also, after you have pushed out both wires, you'll need to push the metal tabs up again so that they will snap back into the harness. again, you'll see what i'm talking about when you see it. be careful not to break the tabs too!
Old Mar 5, 2005 | 01:15 PM
denial's Avatar
ever noticed when the turbo timer kicks in (right after you turn off the car) the idle of the car kinda drops real quick and then goes back to normal? that's the "hick-up." if you switch those two wires then you'll get a transitionless transition between turning off the car and when the turbo timer takes over.
Old Mar 5, 2005 | 01:17 PM
tke_413's Avatar
What if I just cut the wires, switch them and solder them back together.
Old Mar 5, 2005 | 01:19 PM
denial's Avatar
that'd work too i guess. but i'm telling you, taking out the wires is a piece of cake. took me maybe 3 minutes IN THE DARK. try to find a small screwdriver (like one you would use on computer screws). just give it a shot. if it doesn't work i GUESS you can cut the wires.
Old Mar 5, 2005 | 01:20 PM
tke_413's Avatar
Ok, going out to the garage...I'll try your idea first. :P
Old Mar 5, 2005 | 01:24 PM
denial's Avatar
good luck, let me know how it goes.
Old Mar 5, 2005 | 01:32 PM
tke_413's Avatar
Ok, so after I took the plastic piece off under the steering wheel to get the the plug it took about 30 seconds to switch the wires. Works like a charm now. THANKS!!!!!!
Old Mar 8, 2007 | 08:21 PM
trinydex's Avatar
can someone tell me the function of the green and blue wire? are they both power? what are tehy freakin' for? and can i actually use them for a gauge install?
is there an acc power wire on teh greddy tt harness? red is consstand 12v right?
mdknutsen
Jul 12, 2016 05:51 AM
evobob8
Site Feedback / Suggestions
26
Aug 26, 2011 08:24 AM
leecavturbo
20
Sep 30, 2009 05:17 AM
NIevo
12
Jan 2, 2007 08:55 PM
