How To: Install WeaponR custom EVO8 Catch can w/pics
Old Mar 18, 2005 | 07:52 AM
Shaker Motorsports's Avatar
Step 1: Remove the two bolts holding the strut tower brace in place. Place the catch can on top of the strut tower brace and bend the tab on the catch can under the lip of the hood. Flex it gently, you might scratch the strut tower brace but nothing bad. Reinstall the bolts. This pic shows the can installed and the first part of hose clamped on. Also, if you don't want the reflection of any scratches on the strut tower brace coming off the can, place the large sticker on the foward face prior to install.
Attached Thumbnails How To: Install WeaponR custom EVO8 Catch can w/pics-uppernipcan.jpg
Old Mar 18, 2005 | 07:53 AM
Step 2: Locate the upper connection on the front right top of the engine and the lower connection just below the blowoff valve.
Step 3: Run the provided hose, where you would like it to be after the final install, from the left oil can connector to the one on the top of the motor and then cut leaving an extra 2 inches of hose.
Step 4: Remove the hose from the top of the engine and attach the new hose with the clamp, then run it to the catch can and connect it with the clamp. (see above image)
Image 3 shows the following: Arrow 1: new hose with clamp, arrow 2 old factory hose, arrow 3 shielding to remove and use on the hose.
Attached Thumbnails How To: Install WeaponR custom EVO8 Catch can w/pics-uppernipafter.jpg   How To: Install WeaponR custom EVO8 Catch can w/pics-lowernip.jpg   How To: Install WeaponR custom EVO8 Catch can w/pics-uppernipold.jpg
Old Mar 18, 2005 | 08:00 AM
Now the tough part.
Step 5: Run the remainder of the hose from the lower connection to the right side of the catch can. Cut it leaving and extra 2 inches. Remove the hose from near the BOV and attach the new hose and clamp. This is touch but the hose is firm and can be pressed on from a distance. Remove the shielding from the factory hose and place it on the new hose. Now run the hose to the catch can and connect with the final clamp. Done, 15 minutes!
Attached Thumbnails How To: Install WeaponR custom EVO8 Catch can w/pics-lowernipafter.jpg
Old Mar 18, 2005 | 08:04 AM
Evolution23's Avatar
Nice write-up. Thanks. Looks really. I might need to pick one of these up.
Old Mar 18, 2005 | 08:07 AM
Moderator, can we make it sticky?
Old Dec 20, 2005 | 05:03 PM
sr21racing's Avatar
I installed the same oil catch can on my evo, but I am having a bit of a problem...I have lots of mods done to the engine, new turbo, new blow off valve, intercooler, radiator....well mostly everything but the engine itself. I am a newbie at mecanic and mods so be patient with me...
My problem is that I don't have ( or can't find ) the lower hose connection below the blow off valve ( which is in a completely different place then stock btw ). So the only connection I have is from the right side of the engine block the the left side of the catch can. Before I installed the can, I used to have a little air filter attached direclty to the right side of the block, i didn't have the stock lines anymore. The lower connection is gone due to my mods, so what do I do with the right exit connection of the can ??? Will attaching that little filter there be ok ?
If you need any pics of the engine to further understand what I'm talking about, let me know and i'll take some. Thanks for any help you guys can provide !!!
sr21racing
Old Jul 18, 2009 | 11:16 PM
k20toEVO's Avatar
i have the same problem.. do we create a nipple on our new intake pipe?
Old Jul 19, 2009 | 12:04 AM
xspsi4's Avatar
Holy 4 year old thread batman
Old Aug 21, 2009 | 06:27 PM
k20toEVO's Avatar
well why create a new one IM sure im not the only one that upgraded their turbo and have this
Old Dec 29, 2009 | 04:53 PM
IndyEvoVIII's Avatar
I put this catch can on not too long ago and found it was a quick and easy bolt-on. Good write up.
Old Aug 30, 2010 | 03:59 PM
havok1212's Avatar
Anyway you can connect the pcv valve to it also.
Old Oct 2, 2010 | 08:59 PM
AboodsEvo's Avatar
Anyone knows what specs the hoses are mines are getting old and need to change them...
doncarbone
Oct 17, 2016 01:34 PM
Raceghost
May 11, 2016 01:14 AM
03_Lancer_ES
Jan 25, 2007 07:13 PM
defeated26
Oct 12, 2003 12:21 PM
Kurt
12
Oct 10, 2002 10:05 PM
