How To adjust Brake Light Pedal Switch.
Old Mar 27, 2005 | 03:19 AM
mrbkkt1's Avatar
If you are like me and your car came from the factory w/ too much play between Braking, and the light coming on, and does not want to waste time going to a dealer, making an appointment, and actually showing up for an appointment,here is how to adjust the switch:
1. Push driver seat all the way back.
2. Take flashlight and look at top of brake pedal to find brake light switch.
3. The switch will rotate about 1/4 turn. turn it and then you can move the switch up and down on it's track.
4. Adjust and then turn switch back 1/4 turn to lock in place.
5. Check with mirror that switch is activating with the desired pressure on brake pedal.
I decided not to list clockwise/counterclockwise, cause you will only get confused working upside down. If anyone actually needs pics, then either you need to take it in for servicing, or you just really love pics for the hell of it.
I will post pics if needed.
Old Apr 5, 2005 | 11:50 AM
Coolguy949's Avatar
Great post!
Also, do you know how to adjust the e-brake itself? For some reason mine engages super high. Feels really loose.
Old Apr 25, 2005 | 08:41 PM
timmiii's Avatar
if it doenst bother you can you post some pics please?
Old Jun 8, 2006 | 12:45 AM
DaveLC2's Avatar
Thanks for the info. This drives me nuts! When I go around this one down hill s-turn I can see the brake light flashing or it's actually full on while I taking hard lefts it just drives me bonkers! It's almost 1 am so I'll mess around with this in the morning. Thanks.
Dave
Old Sep 19, 2006 | 02:03 PM
julianc's Avatar
For those who need to know which direction to turn the switch, if you imagine yourself looking at the wire connector end of the switch (not the plunger end), you would turn it counter-clockwise.
Also, try to make a note of how far the pedal has pushed in the switch plunger before you loosen it. Once the housing is loosened, the switch will spring loose from the bracket due to the pressure on the plunger. Noting where it was when you started will help you determine how far to adjust it.
Old Dec 16, 2006 | 11:42 AM
Jewish Santa's Avatar
Can you post some pics, My Girlfriend was following me and I was slowing for a light and she said my brake lights never came on... So I would like to adjust this.
Old Mar 11, 2007 | 04:35 PM
krillin's Avatar
Old Oct 12, 2007 | 03:18 PM
mitsumanny's Avatar
how the hell do u get ur hand in there?
Old Apr 15, 2009 | 04:23 PM
Jp7's Avatar
Jp7
I got my hand in there but I cant get it to turn either way! Is there a trick to getting it to unlock, I was really trying hard.
Old Apr 26, 2010 | 05:45 PM
from_Si_2_Evo's Avatar
i cant even turn it. Jp7 did you figure it out
Old Apr 26, 2010 | 11:38 PM
Jp7's Avatar
Jp7
lol, no - I can't get it to unlock.
Old Feb 22, 2011 | 05:08 PM
s7krew's Avatar
Bringing this thread up before it hits a year, but i cannot for the life of me get the damn thing to turn either way...just wondering how ended up doing it
Old Feb 22, 2011 | 05:47 PM
Jp7's Avatar
Jp7
I haven't yet... I drove my car 500 miles last year. I will try again this year. I've got to be doing it wrong.
Old Dec 21, 2019 | 07:23 PM
akachi's Avatar
bringing this thread back up because i can't turn it either way. it seems very hard. any trick to it? perhaps a video?
MasterAK
Lancer How Tos / Installations
58
Aug 19, 2020 10:45 AM
GrannyShifting
Mar 21, 2017 05:25 PM
Weathergeek
Aug 24, 2015 08:48 AM
bLizTIc
Aug 12, 2012 06:06 PM
avengerhed
Feb 22, 2005 11:15 AM
