Painting your trunk lock
Old Apr 15, 2005 | 06:03 AM
twan's Avatar
I had mine done...looked good for a while then it started to chip off.
How does one prep this good enough? Will paint ever adhere to it correctly cause its stainless steel, i read. Any tips are appreciated.
This is what it looked like before, its all chipped now tho
Old Apr 15, 2005 | 11:51 AM
EVOTEXAS's Avatar
Be careful when you put the key in and it won't chip up. Mine has been painted with Krylon (cheap spray paint) for a year and it hasn't chipped at all.
Old Apr 16, 2005 | 09:02 AM
twan's Avatar
I never used the key on it once...............guess I will try krylon
Old Apr 16, 2005 | 09:04 AM
housedj's Avatar
Thumbs up
you could powdercoat it but that's a little more than Krylon. Krylon is the best spray paint you can buy. if it wasn't for the NYC graf artists, they'd be outta business!!!!!!!!
Old Apr 16, 2005 | 01:13 PM
Red Dragon's Avatar
how do you guys paint it??? dose you take the lock out or do you like mask off the whole area??? I was thinkin that i should give this a try?? thanks
Old Apr 16, 2005 | 01:31 PM
lil'evil_evo's Avatar
i think most leave it on and just tape around it.
Old Apr 18, 2005 | 07:12 AM
sleet's Avatar
Powercoating it would be stupid, just remove it and paint it. It takes 3 seconds to remove the lock, try using some primer on it to keep it from chipping.
Old Apr 18, 2005 | 08:09 AM
SuperHatch's Avatar
try getting some fine grit (2000 grit) sandpaper to rough up the surface ever so slightly first. This will help the paint "bite" onto the surface.
Old Apr 18, 2005 | 08:12 AM
DCSilvrEvo's Avatar
That looks really good!!! are you going to put a clear coat on it?
Old Apr 20, 2005 | 09:36 AM
twan's Avatar
It looked really good..........till 2 months (winter) later when it was all flaky and chipping.
Ill try to sand it up and prime it then paint. As im told tho, there will always be problems with it sticking to stainless steel.
Old Apr 20, 2005 | 09:38 AM
twan's Avatar
P.S. dont paint it on the car, it comes off in 30sec.
Old Apr 20, 2005 | 09:46 AM
UT_Evo's Avatar
That's a smart mod for the other color evos... it already looks just fine on silver though!
Old Apr 20, 2005 | 09:52 AM
wingnut17's Avatar
just don't use you key on the lock if you paint it and it shouldn't chip. Just use your lever inside the passenger compartment.
Old Apr 20, 2005 | 09:53 AM
Kwman's Avatar
wait wait, how do you remove the lock?
Old Apr 21, 2005 | 07:15 AM
twan's Avatar
wingnut17: mine chipped and i never used the key in it ever. its just hard to get the paint to adhere to the SS trunklock in the NY winters i guess with the temp changing alot
Kwman: look on the underside of the trunk, remove a sliding hangar, snap the rod out of the yellow clip, lock comes off.
