INstalling Component Speakers in front
OKAY -- I need some help... I would like to install a Component System up front in the EVO but NOBODY can give a step by step...
Everyone tells me that it is easy but how is it done?
Please HELP
Please HELP
Did mine last weekend, Polk MOMO's 6.5" Set. Worked out great, they needed about a 1/2" spacer to clear the window. I mounted the tweeters in the stock location. I used the mounting cup that came with the set and screwed that to the mounting bracket for the stock tweets and popped in the new ones. Slick as ****!! Run the wires to the speakers, Hook up to the Crossover, and run to a amp!! feel free to IM on AIM nhsean69 if you need anymore of a explaination or have a specific question you need answered. I See you are in Boston, im on the MA/NH line in Nashua, Take a spin up, more then happy to give you a hand if you want or whatever. I work cheap !!! . Im too lazy to make a write up!!
Please HELP
Please HELP
Just installed my MB Quarts today (again). They look like this ( https://www.evolutionm.net/registry/....php?mid=19919 ). The hardest part for me was running heavier gauge speaker wire through the "rubber tunnel" from the side of the car through to the door.
Just installed another set of Polk MOMO 6.5" components in the rear, with the tweets flush mounted in the C Pillars. Now ive got matches set in the front and rear. Sounds insane!!! Sounds soo good i removed my subs and am going to just run a small 10" for the filler low sound.
therunningskier
Apr 14, 2020 09:50 AM
Evoguy!123
Apr 28, 2016 11:51 AM
