official PLX R-500 install thread
Old Sep 1, 2005 | 06:58 PM
  #46
w8less1der's Avatar
Originally Posted by djmikeymike
i returned mine because i couldn't see the screen doring the day
Mine is fine. Where did you have yours mounted?
Old Sep 1, 2005 | 07:08 PM
  #47
Cajun Power's Avatar
kewl
Old Sep 1, 2005 | 11:40 PM
  #48
djmikeymike's Avatar
it didn't matter where i had it mounted!!! any time there was sun light (direct or indirect) i couldn't see the display............ they should have used the same diplay the AFC uses
Old Sep 2, 2005 | 04:01 PM
  #49
Gruppe-S's Avatar
I talked to them regarding this matter two months ago and they have changed the display design.
Tom
Old Sep 3, 2005 | 08:39 PM
  #50
w8less1der's Avatar
I took a look at mine today in the direct sunlight and it is a bit hard to read, but you can see where I have mine mounted - directly in the sunlight when my window is open! If you move it somewhere else you should be fine.
Old Sep 10, 2005 | 09:08 AM
  #51
SterlingEvo's Avatar
Subscribing. I just bought an M500 from another member and will be installing next week Fortunately, I've already had a separate bung welded in from previous tuning, so it will be pretty easy.
Old Oct 21, 2006 | 11:26 PM
  #52
tribe's Avatar
I'm 75% done with my install. Here's a picture. I just ordered a blank din plate to fit around the unit.
Old Oct 21, 2006 | 11:28 PM
  #53
tribe's Avatar
Has anybody logged the MAF signal? The wiring diagram shows the MAF signal as analog, but I believe it should be frequency. Anybody know for sure? And what conversion factor did you use?
Also, anybody figure out the conversions for Hz to RPM, Hz to MPH?
Old Dec 29, 2006 | 08:47 AM
  #54
tribe's Avatar
I've found a few flaws with the R-500, but overall it's a great unit. Anyone else having issues with the analog output? Mine is intermittent.
Old Mar 6, 2008 | 05:12 PM
  #55
silex's Avatar
Bumping this as I'm trying to locate another O2 sensor harness that works with this unit. Somebody please point me to someone/company that has one for sale. It's the same cable that comes on the M-series as well.
Old Mar 7, 2008 | 08:12 PM
  #56
silex's Avatar
Somebody has to know...please I really need one!
superscout03
12
Mar 2, 2008 02:23 AM
drucea
Jan 3, 2008 04:13 PM
streetrays
19
Jan 24, 2006 08:16 PM
djmikeymike
May 3, 2005 10:20 AM
streetrays
Aug 16, 2004 12:14 PM
