Wheel hub removal and lug/wheel stud installation
Ok so I never got
Around to posting pics up. Sorry guys, as long as everything is unbolted just yank the hammer nice and hard. Even a freshly replaced hub can be stubborn once it sets in there
My advice: Use a slide hammer, but if it seems like you're yanking way harder than is healthy, stop before you make an expensive mistake like I did.
yea same here, have been working on this all night and soaking it with penetrating oil. I cant get the hub off every bolt is out and i have been waling it with a hammer
**** just wont come off.. any advice?
im wondering if i am starting to do damage VS getting the hub off. all the bolts are out and i been beating the hell out of it trying to get it off. the hub is coming out but its not where the back side is bolted to the spline. did i trash the hub? or should i use a bigger hammer. lol
update
i got the hub out. but there is a little wobble in the assembly. ok or replace?
update
Here's another thread for removing the hub.
Hub
https://www.evolutionm.net/forums/ev...b-bearing.html
Studs
https://www.evolutionm.net/forums/ev...safe-easy.html
Hub
Studs
Just replaced my driver front hub today, where it says above a few 'light taps', I had to instead 'beat the living **** out of it' with a hammer and large mason chisel. But I did eventually get it out. The process was much easier than the effort to get the hub free from the knuckle but I do live in the northeast, dd my car year round and have 105k miles
vtluu
74
Dec 28, 2015 01:01 PM
