Forge MBC installation
Old Jun 8, 2007 | 10:12 AM
Dosagex's Avatar
Nice write up.
Old Jun 18, 2007 | 02:58 PM
evolved83's Avatar
*edit nevermind
Old Jul 17, 2007 | 08:31 AM
IAmADirtDude's Avatar
once everything is installed how do you go about adjusting your boost controller? i have my gauge, my mbc and everything i just need to figure out how to adjust it and get it where it should be i hear stock is near 18? please help me out and expand on this thanks guys
Old Jul 17, 2007 | 09:57 AM
schred86's Avatar
turn it all the way down initially, then increase boost after doing a 4th gear pull, just keep repeating the process until u are dialed in
Old Jul 17, 2007 | 10:43 AM
so im guessing thats all the way clockwise (all the way down)? then watch my guage as im doing those 4th gear pulls and try keeping it around 18psi? i want to stay close to stock is it bright to turn it higher than stock for a daily driver and once a month road racer? thanks guys sorry if this is a newbish question but have never dealt with this
Old Jul 18, 2007 | 03:35 PM
schred86's Avatar
there should be a + and - sign, i think counter clockwise will lower(decrease boost) it if i remember correctly
schred86's Avatar
Old Sep 23, 2007 | 04:20 PM
h.funk's Avatar
The best way to get the hoses off the waste gate is to use heat. I used a lighter to warm up the hose and it slipped right off. Dont leave it on too long.
Old Sep 30, 2007 | 10:51 AM
tougetuned's Avatar
just had a question about how many clicks of the mbc it took to reach 19-20psi with the soft spring installed?
Old Nov 12, 2007 | 12:49 PM
hokiruu's Avatar
In the original writeup, "turbo outlet duct" is incorrect and misleading, it is the turbo INLET duct aka intake tube from the MAF to the turbo.
Old Nov 20, 2007 | 07:17 PM
350zEvo8's Avatar
So on the boost soleniod in pic3 in the original post..we are putting tubing across those 2 ports connecting them to each other. Then connecting the MBC to the hoses from the wastegate and the nipple? Did i understand that right?
Old Nov 20, 2007 | 07:41 PM
hokiruu's Avatar
Yes you did.
Some of the posts here make this sound way more complicated thatn it really is.
I did the whole thing in a little over an hour in my gravel/mud driveway in 20 degree weather in the dark taking my time, WITHOUT removing my UICP, and definitely not the fan or anything.
Just remove the airbox and turbo inlet, disconnecting all the hoses. Plug the small hole on the bottom side of the turbo inlet with something like a bolt, screw, or the plug from one of those stupid plastic POS panel fasteners most of us have broken dozens of (what I did, works perfect).
Use a lighter for about 30 secs on the hose ends at the turbine nipple and waste gate nipple and yank them off, "Y"/"tee" fitting/"restrictor pill" and all.
You can either cap off the stock boost control solenoid fittings or just use a hose to route them to each other, doesn't really matter.
Route new hose from turbine nipple to bottom of boost controller. Route new hose from fitting on the side of the boost controller to the wastegate. Don't forget to put the clamps onto the hose before pushing it onto the fittings unless you are using some other kind of clamping thing like a ziptie.
Reassemble turbo inlet, attaching the crankcase vent hose that pisses oil vapor into your turbo inlet, which hopefully you have a catch tank plumbed into. (If not see my catch tank how-to.)
Reattach airbox.
Done!
Old Nov 20, 2007 | 08:41 PM
350zEvo8's Avatar
Well i may have a little easier time since my stock hoses are removed and the MBC was uninstalled leaving me at 12psi...Hopefully for me its just plug and play.
Thanks hokiruu!
Old Nov 26, 2007 | 12:09 PM
350zEvo8's Avatar
I just installed a turbo Xs MBC, my car had the 12psi problem...i only had to remove my airbox..plug and play.
Old Mar 27, 2008 | 09:26 PM
JZEVOIX's Avatar
i am going to try this tomorrow along with my boost gauge. what should the psi be stock doing to 4th gear pull? and what is the safest psi to go up to without a tune?
thanks,
Jay
