turboxs knocklight help
Old Dec 26, 2005 | 07:27 PM
tah78's Avatar
i just intalled the knocklight, i know i got the tach wire correct, but i'm not seeing any knock, even on the highest sensitivity....if anyone knows what wire to tap, it would be very helpful...btw, i tapped the fat white wire on the far left of the ecu, theres some silver tape from the factory on the wire...thanks in advance for any help
also, i know that it might not be showing any knock because there is none...but i just want to make sure i got the right wire
Old Dec 29, 2005 | 07:49 PM
C6C6CH3vo's Avatar
The guys at turbo xs recomended leaving the stock knock monitoring system as is and purchace another sensor (bosch $90) and screw it to any of the availble places on the block.
Have someone close the hood and see if the light flashes, also do a third gear pull throughout the rpms.
Whatever you do don't put bad gas in there and/or up the boost to see if the lite works JK, but just in case - dont
Old Dec 30, 2005 | 12:08 PM
tah78's Avatar
sounds good...thanks for the help
Old Dec 30, 2005 | 12:13 PM
okevolutionVIII's Avatar
Let us know how well it works because I planned on getting one myself.
Old Dec 30, 2005 | 01:53 PM
EvilBlueEvo8's Avatar
make sure you have the right wire
http://www.evomoto.com/tech_info.php...3_5&tech_id=19
Old Dec 30, 2005 | 03:39 PM
tah78's Avatar
well...i have it hooked up right now to the stock sensor tapped off the ecu...btw, the ecu diagrams are extremely confusing...i suggest you count the pins on the chart and on the ecu twice before striping back any of the insulation, its the only way to get it right...the lights working properly...i find it to be extremely sensitive, i still have some adjusting to do to get it right...but as a shift light, it works well, and is nice and small, and you don't need to add a big *** tach in your car...i'll post up after i get the bosch sensor...and if anyone wants to know the wire colors for the tach and knock, let me know...
Old Dec 30, 2005 | 04:13 PM
thats kewl that you got it working. i have no problems with electrical since i"ve been working on vehicle electrical and audio systems for years. where did you mount it and how did you do it? i have one too but haven't had time to put it in yet. any pics?
Old Dec 30, 2005 | 06:54 PM
tah78's Avatar
i mounted it on the the steering column...the velcro they give you doesn't hold it at all, so i drilled tiny holes to tie strap it in place...i'll post up pics soon...
Old Dec 30, 2005 | 07:17 PM
tah78's Avatar
this is my first attempt at posting a pic....hopefully it comes out ok...
/img522/5240/img00025qk.th.jpg[/IMG]
Old Dec 31, 2005 | 06:51 AM
nice. i didn't get any velcro. i was going to use a pclamp but i'm undecided between the air vent and the steering column.
Old Dec 31, 2005 | 03:58 PM
tah78's Avatar
if you know which bosch sensor to use, please post a link...i would rather use the seperate sensor than the stock...thanks again
Old Jan 2, 2006 | 10:59 PM
evopower1021's Avatar
i bought the bosch knock sensor, just call turbo xs and you can buy it directly from them with the pigtail harness.
Old Jun 22, 2006 | 11:09 AM
justchil's Avatar
I'm curious where you mounted the knock sensor.. any pics of that?
Old Jun 22, 2006 | 01:01 PM
dont know who you are talking about but i haven't got around to mine yet. i'm going to do it in the center air vent though. there are instructions and pics in the how to section
Old Jun 22, 2006 | 01:40 PM
justchil's Avatar
I mean the sensor itself... I could be confused tho.
J8dailo
Mar 1, 2010 02:25 PM
tobz
Dec 10, 2008 01:34 PM
dudical26
16
Jun 6, 2007 12:13 PM
Inprogress
Dec 4, 2006 02:16 PM
Deepseadiver
Oct 22, 2006 07:40 AM
