Rotor Removal Stuck??
Old May 4, 2010 | 05:37 PM
  #31
FooM Anchoo's Avatar
going to be changing my rear brakes and rotors this week. Thanks to everyone who posted up and making my task easily understood
I love this forum
Old May 5, 2010 | 04:30 PM
  #32
dolson222's Avatar
Good call on the brakes and in gear. I used a 4 ft metal pry bar inbetween the studs and rags to protect the threads cuz i was alone. I wouldnt recommend that as a first choice but if all others fail it works.
Old May 5, 2010 | 06:11 PM
  #33
rgonyer's Avatar
No kidding, I had a stuck front rotor. I never knew about those M8 holes. I beat that rotor with a rubber mallet for 20 minutes yesterday and it wouldn't come off. Two cranks with an M8 bolt and it popped off like magic.
Old Jul 31, 2011 | 12:21 PM
  #34
08Lancer89's Avatar
I want to put extended studs In the rear or my 2009 Ralliart do I use this same concept?
Old Oct 12, 2011 | 07:54 AM
  #35
qiksilver's Avatar
OMG the tip to use the threaded hole on the rotors just saved me hours of frustration
Old Oct 21, 2015 | 07:16 AM
  #36
swatteamtimmah's Avatar
Sorry to bring this back from the grave, but this thread was incredibly useful, I just did a pad/rotor change on a '12 Evo X that I recently picked up and I was second guessing myself when it came to the rear rotors when they wouldn't pop off. I've never encountered a E-brake tension issue that prevented the rotors from just sliding off. The M8x1.25 bolts worked however.
Also, the e-brake tensioner that is mentioned in previous posts was located behind a rubber grommet on the front of the rear rotors hats.
Green_Bandit
21
Sep 9, 2019 02:14 PM
pckiller00
14
May 9, 2016 09:30 AM
LANEVO creazy
Mar 17, 2016 10:09 PM
EVOlutionary
90
Feb 8, 2016 09:45 PM
David Buschur
30
Jan 23, 2016 04:23 AM
