I have Non HID Foglight headlights and want JDM MR
Old Feb 16, 2006, 10:13 PM
JDMonster's Avatar
Ok i have the NON HID headlights and do not have the foglight in my EVO 8. I want to get a HID conversion online and the JDM MR headlights. How hard is it going to be for me to wire in the foglights and locate a factory switch and all that? Is there a easier way for me to get fog lights in my headlights? any other options at all.
Thanks
Old Feb 17, 2006, 04:29 PM
JDMonster's Avatar
No help?
Old Feb 27, 2006, 06:04 PM
caligula's Avatar
simple you need to go to the dealer and get a fog light switch,fog light relay and thats all i think.good luck
Old Mar 2, 2006, 08:55 AM
WavMixer's Avatar
Wrong! In 05 the RS and GSRs did not have all of the connections in the fuse block for the relay and fuse. You will need to fabricate everything. I have created a walk thru on what needs to be done:
https://www.evolutionm.net/forums/sh...&highlight=hid
Old Oct 27, 2006, 07:18 PM
Illrunya's Avatar
Is the IXs the same deal? Does everything have to be fabricated?
Kenny
Old Oct 30, 2006, 11:46 AM
TDeMent's Avatar
I am curious about this too for the IX.
Old Oct 30, 2006, 12:29 PM
UCB
UCB's Avatar
Im just going to buy an aftermarket fog kit and use the harness that comes with it
Old Nov 1, 2006, 12:51 PM
Illrunya's Avatar
What type of aftermarket fog kit do you plan to buy? Is there an aftermarket fog kit that is identical to the OEM foglight setup within the headlight housing?
Kenny
Old Nov 6, 2006, 07:18 PM
IguessNot's Avatar
Thanks
same question but i have a IX
Old Nov 7, 2006, 05:55 AM
jrod0187's Avatar
+1 for the foglight install on a IX
Old Nov 7, 2006, 09:07 AM
UCB
UCB's Avatar
Kenny
Im just going to buy a cheap-o H11 fog kit off ebay, use the wiring harness it comes with, and plug them into the H11 bulbs (what the MR/SSL fog lights use), the route the harness to the cabin and use some cheap-o switch. Its just 2 bulbs to light up, all you need is the proper power cords, a relay, and a swtich
IIRC, the there is no real way to use the OEM fogs without a custom harness unless you switch over the entire engine harness
Old Nov 7, 2006, 12:00 PM
thedarkside's Avatar
+1 I really need to get some fogs
Old Jun 25, 2007, 05:45 PM
WavMixer's Avatar
Kenny
Anyone find an answer to this yet?
Old Jun 25, 2007, 05:52 PM
mrbkkt1's Avatar
O.K., here is the deal, you will also need a front ecu from an evo that has foglights, in addition to the switches and what not.
also, authentic JDM headlights use H7 bulbs, not H11.
the standard switch for the foglight in an evo is not a normal switch, it sends a signal to the front ecu to turn on the fogs.
easier to run a separate harness, switch, and wiring IMHO.
Old Jun 27, 2007, 03:48 PM
djulian21@juno.'s Avatar
does anyone know how to convert HID to non HID?
Quick Reply: I have Non HID Foglight headlights and want JDM MR
