How To Black out Headlight (Detail)
Old Dec 10, 2006 | 05:02 PM
Kizzao's Avatar
nice job... you can black out anything these days
Old Jan 1, 2007 | 07:20 PM
stevEVO8's Avatar
What heat guns are you guys using and what heat range settings are we talking about?
Are you passing over each area and slowly workign your way around or heating all of the way around before pulling apart?
Old Jan 7, 2007 | 09:09 AM
zachissak's Avatar
LOVE the blacked out look nice write up
Old Jan 10, 2007 | 10:26 AM
Evoryder's Avatar
Bake in oven first...would use a hairdryer on top level...now i use a simple homedepot heatgun on the lower level...high will melt the housing if not careful...which u don't want ...u can't un-fry an egg right .
Old Feb 26, 2007 | 07:17 AM
MisterMR's Avatar
Do you really need to remove the bumper to take the headlights off? Or can you get to the 4 bolts without taking the bumper off?
Old Feb 26, 2007 | 07:54 AM
Dead-Man Inc's Avatar
you have to take off the front pumber to remove the headlights ..
Old Feb 26, 2007 | 08:02 AM
str8kor's Avatar
haha that's awesome, who woulda knew
Old Feb 26, 2007 | 08:50 AM
Evoryder's Avatar
...don't have to completely remove the bumper, but it's alot easier to work with it removed.
Old Jun 8, 2007 | 09:28 AM
Dosagex's Avatar
Nice detailed write up.
Old Jun 8, 2007 | 09:31 AM
Dosagex's Avatar
looks kinda hard though.
Old Aug 1, 2007 | 08:30 AM
i<3boost's Avatar
im gonna try it with mine
Old Aug 12, 2007 | 04:39 AM
Jakeg97's Avatar
Originally Posted by Evoryder
] NOw, remove all the other goodies on the headlight....city light bulb, indicator bulb harnesses, ballast ...disconnect ground from ballast. headlight should be ready for cooking. All that should remain on headlight is projector glass, HID levelling motor, ground for ballast and thats it...nothing else can come off with ease.
i recommend removing the hid leveling motor
i read a post that someone baked it and then it didnt work right after
plus
you can easily remove the hid motor as it just a ball and joint snap. disconnect the motor and with one hand holding from the inside , pull up/off hard. it will come off with a snap and putting it back in is much easier
Old Aug 12, 2007 | 10:37 AM
Evoryder's Avatar
plus
good stuff...no motor probs here though...
Old Sep 11, 2007 | 10:04 PM
reggiesd's Avatar
so the specified time on the oven for the headlights..would it be the same amount of time for the tail lights?
Old Sep 11, 2007 | 10:15 PM
Evoryder's Avatar
negative. You don't bake your tail lights..you gotta use a heat gun and a exacto knife...tails are a PITA!!!!!
