Timing Belt How to...
Old Dec 12, 2008 | 01:21 PM
  #91
EvoHung's Avatar
Okay so does the cam gears line up to the mark on the valve cover every time the crank pulley's marks lines up? I had some idling issues and took my cam cover off to see if it lines up and it seems like when I line the crank pulley up to the "+" mark, my cam gears are about one tooth off each. Could my timing have slipped a tooth?
Also, when the engine is running, my belt does not look like its running smooth, it runs kind of flappy. Is that normal??
Old Dec 12, 2008 | 03:01 PM
  #92
56Hotrod's Avatar
My recollection is there are 18 teeth between the 2 pullies. If one tooth slipped, you'd know by counting. If 2 teeth slipped (one on each pulley), you would only know by the crank angle mark to the timing gear marks.
Old Dec 31, 2008 | 11:12 AM
  #93
bboypuertoroc's Avatar
Veteran: Army
Did anyone save the PDFs from the first two posts?
Old Dec 31, 2008 | 11:24 AM
  #94
scheides's Avatar
EvoM Moderator
Yes, but they're still in the first post....what's the problem?
Old Dec 31, 2008 | 11:27 AM
  #95
Veteran: Army
I tried opening them and it says "There was an error opening this document. This file cannot be found.".
Old Dec 31, 2008 | 01:54 PM
  #96
56Hotrod's Avatar
I have them plus the PDFs of the factory service manual. PM me with your email address and I'll send them your way.
Old Dec 31, 2008 | 04:00 PM
  #97
Veteran: Army
^ Thanks.
Weird though, I tried opening them at home and they worked fine. Got them now saved. I'll be tackling this (just the belt part) on Friday.
Old Dec 31, 2008 | 04:06 PM
  #98
TIBOevo's Avatar
18?, i thought it was 17.
Old Dec 31, 2008 | 06:26 PM
  #99
56Hotrod's Avatar
I'm 97% sure it is 18. Can someone else verify?
Old Dec 31, 2008 | 06:30 PM
  #100
56Hotrod's Avatar
I'm 99% sure it is 18 for the EVO 8s. Not 100% sure with Mivec.
Check out:
https://www.evolutionm.net/forums/ev...as-wanted.html
That is, start at your front timing gear and its mark. Start counting the teeth on the timing belt to the left side of this mark, and end on the left side of the rear timing gear mark. Thus, that would mean 17 between the marks...but that wasn't the way I was counting
Old Jan 25, 2009 | 10:31 AM
  #101
EvoHung's Avatar
Okay, so when the tensioner pulley is in its correct position, which direction does the two holes face? Down or up?
Old Jan 25, 2009 | 05:22 PM
  #102
MitsuJoe's Avatar
Post a picture...that will help a lot here!
Old Jan 25, 2009 | 06:28 PM
  #103
EvoHung's Avatar
Well, I ended up tightening it at the 5 O'clock position.
Old Jan 25, 2009 | 07:02 PM
  #104
MitsuJoe's Avatar
Really what is most important is where you able to put the pin back in the tensioner after 15 minutes?
Old Jan 25, 2009 | 07:36 PM
  #105
EvoHung's Avatar
No I was not able to. Am I suppose to?
