HKS CAM INSTALL ISSUES :( not good
Old Apr 14, 2006 | 07:42 PM
Evolento's Avatar
just installed hks 272's and hks cam gears and we think the timing may have jumped a tooth on the exhaust side i kno we are probly screwed whats the proper way to fix if anyone can help please do its very important my car is stuck at a friends house until we can get it running thats alot
EVOLENTO
Old Apr 14, 2006 | 07:57 PM
sleet's Avatar
Line that **** back up.
Old Apr 15, 2006 | 03:47 PM
bbbwrx's Avatar
Basically you will need to do the service as if you were replacing the timing belt. Rip off everything on the side of the motor. Then loosen the belt line it back up. Rotate it around a couple times making sure your timing marks line up.
I am guessing it happened when trying to break the cam gear bolt free?
Ben
Old Apr 15, 2006 | 03:49 PM
bbbwrx's Avatar
Or i guess you could move it back since you have the timing belt loose. Then just make sure the cranks and cam gears all line up with the timing marks. But there may be the chance that something is not right near the water pump or idler pulley if you have ti that loose
Ben
Old Apr 15, 2006 | 03:55 PM
MalibuJack's Avatar
The way the belt stretches, stuff doesn't always perfectly line up, but if you really hosed the install then the only real way to fix it is to do the equivalent of a timing belt R&R..
It seems alot harder than it is because there's alot of disassembly, but its not that bad if you take your time (don't rush through it) once you have the bottom cover off, you can realign all the timing marks (Try to find a good document that CLEARLY shows where all the timing marks are, the first time I did it I had a hell of a time finding them) Then line them up and put the belt back on.. After doing it I realized that its a long install, but alot easier than it seems.
Once you have slack in your timing belt, its just way too easy to slip a tooth if you are doing the install alone.. Don't feel too bad it happens all the time.. I even broke the tensioner tool on my own car so it happens to everyone.
Strictly Modified
Evo 'For Sale' Engine Internals and Drivetrain
62
Mar 3, 2014 10:11 AM
Evolento
Jul 1, 2010 06:28 AM
Evolento
Aug 30, 2007 09:59 AM
Evolento
Jul 10, 2007 10:16 AM
Evo Girlie
Mar 18, 2007 09:42 PM
