Adjust hand brake?
Old Jul 17, 2006 | 07:20 PM
skurukutoi's Avatar
isnt there a way to adjust it at the wheels?
bcuz i assume that constantly adjusting at the handle is only stretching the cable more and more, and will eventually possibly potentially SNAP the cable?
im gonna gettin around to gettin a kevlar cable
Old Jul 18, 2006 | 08:14 AM
x838nwy's Avatar
Where can you get the kevlar cable from? Sounds a plan.
Old Jul 18, 2006 | 08:52 AM
WarmPepsi's Avatar
dude, if it was a serious issue, you'd have heard about it.
you don't need no kevlar cable for your e-brake.
Old Jul 18, 2006 | 12:32 PM
ovenmit331's Avatar
EVERY cable will strecth after first installed. i'm a HUGE bike rider. road and mountain. i install brakes on bikes ALL the time and the MAIN thing we tell people, is to readjust their brakes after three month because of cable stretch. and sometimes they need to be adjusted twice, but it eventually stops stretching and all becomes right with the world...
just adjust it at the cable...
Old Oct 30, 2007 | 08:55 PM
sorgar001's Avatar
that is great information. thank you
Old Dec 2, 2007 | 03:37 AM
fugiwara's Avatar
thank you for the great info too, I knew it can be adjusted from the cable, but wasn't sure if it was the same for evo. now sticky this!!
Old Jan 15, 2010 | 05:19 PM
BEZ-01W's Avatar
Exclamation
For the people after the extra info, there is only so much adjustment in the handbrake at the handbrake lever and if this does not resolve your handbrake woes and you find yourself at the end of the thread (ie. tightened all the way to the end), you will need to jack up the car, remove the rear wheels and adjust the hand brake shoes through the 6o'clock hole on the rear brake rotor hubs. Refer to the mitsubishi service manual for more information.
The primary handbrake cable is pretty strong and I don't think you will snap this cable. The secondary cables that run to each rear wheel is thinner and would be more likely to snap. but as said before it is not an issue that comes up often.
Old Jan 15, 2010 | 05:36 PM
revvin9k's Avatar
I just did all my brakes, F+R rotors and pads and decided to do the rear brake shoes as well since I use it a lot to slow down when I see a cop as not to set of my brake lights.
I did not adjust it from in the cabin, I did it from the spindle inside the rear rotor. I guess you can do it from the cabin, but I think it's at least wise to pull the rotors off on higher mileage Evo's, just to see what kind of material you are working with.
Old Jan 24, 2010 | 08:01 PM
silkey00's Avatar
yup. the guy who put my brakes on showed me how to do it.... its not too hard...
Old May 6, 2010 | 12:56 PM
rudebwoyt's Avatar
Thanks guys. great info
Old May 10, 2010 | 06:36 PM
freshkid's Avatar
I need to do mine too. It doesn't look hard to do.
Old Sep 19, 2010 | 01:43 PM
PromDizzle's Avatar
so is it the headless threaded nut under the rubber flap of the handle, or is it the 10mm nut on the passenger side of the pulley wheel? that one doesnt seem to do anything when i turn either way.
Old Aug 15, 2011 | 08:45 PM
liukang1's Avatar
does anyone have a pdf copy of the 2009 mitsubishi lancer service manual?
Old Aug 15, 2011 | 10:20 PM
boosted_em1's Avatar
thanks for the tip
Old Dec 26, 2013 | 01:01 PM
Ghostdriver22's Avatar
Ebrake adjustment
I have yet to tackle this project. Sounds fairly simple just time consuming. -Almost- worth the 40$ if you consider what all is involved. Anyone find the user manual pdf that shows first hand how to adjust at rotor/caliper?
