How to create a stealthy interior, black.
Old Jun 25, 2008 | 08:26 AM
  #121
denver's Avatar
Originally Posted by mikespike2
I saw an evo with a radio surround that was black and matched the rest of the interior texture wise, asked and he said it was stock. Now I'm beating my head trying to find the year/model that had it.
You have probably figured it out by now, but I know the stock '03 OZ lancers have them.... I put mine in my evo out out of my OZ and it looks a lot better!
Old Jun 25, 2008 | 08:29 AM
  #122
mitsuboost30's Avatar
i did this and it looks excelent im just looking for a good suede (alcantra) material to do to the headliner to complete the look!
Old Sep 6, 2008 | 02:12 PM
  #123
kevinoffroad4x4's Avatar
well i started to do my interior and i made a couple passes of pre-spraying to get the paint up to the nozzle which all went well.......then i started to paint my pieces and the can started dripping and spattering everywhere. so now i am at the step of removing paint and trying again with another can that actually works correctly. hope no one has to experiance this....it was a big let down
Old Sep 8, 2008 | 09:06 AM
  #124
used2havahonda's Avatar
I need to get on this... looks sick
Old Oct 16, 2008 | 06:42 PM
  #125
evoguy69's Avatar
i will be installing evo 9 front and rear bumpers on my 8.when i doso i am going to have my dash trim painted the same color.i have not seen this done,i hope it doesnt comeout looking to cheesey.i like the darth vader look youve got going.
Old Oct 16, 2008 | 06:45 PM
  #126
BocaShula's Avatar
looks good
Old Nov 2, 2008 | 04:24 PM
  #127
4G63K's Avatar
How Does it look now after some time has passed? i just did mine im a lil scared on how durable its going to be
Old Nov 2, 2008 | 04:25 PM
  #128
Sharkbite2000's Avatar
That looks real nice !!! Great job!!!
Old Dec 7, 2008 | 07:41 AM
  #129
captainA's Avatar
looks good, did u sand them first?
Old Dec 9, 2008 | 01:54 PM
  #130
TRIPODSSIKEVO9's Avatar
I have done the A-pillers, C-pillers, and both roof light trims. I will be doing the roofliner and the "OH S*@T" handles.
I dont quite know how to take off the B-pillers.
As far as the C-pillers are concerned, You have to take out the rear seat. Once you take that out, you will be able to just pull the C-piller out. You have to take out the rear seat because the back part of the seat will prevent you from pulling out the very bottom clip that holds the piller in. It only took me about 5 minutes to take out the seats and pull out both pillers.
I could use help with the B-pillers if anyone can do a write up about that...
I am using the Dupli Color and the paint is coming out very nice. I did this a couple days ago but have not installed yet. I am wiating to install when I get the B-pillers out and painted.
Old Dec 9, 2008 | 03:43 PM
  #131
Okay. I just figured out how to take off the B-piller. It is a lot easier than I thought. All you need is a 17mm socket and a ratchet.
1. Take off both front and rear kick panels. Just pull them off.
2. Pull off the bottom section of the B-piller.
3. Pull off the front cover to the seat belt. You will se a 17mm bolt that holds it in place.
4. Remove bolt and the seat belt assy. comes right off.
5. Pull out and up on the upper part of the B-piller
and Viola... The B-piller is removed.
Hope it helps.
Old Dec 9, 2008 | 03:59 PM
  #132
Something else...
If you are looking to paint, the slide that is behind the B-piller just pulls right out from the top, making it a lot easir to paint.
Old Mar 20, 2009 | 11:33 AM
  #133
SRTRaceR04's Avatar
I don't know if anyone else has made any other suggestions on the interior paint, but I will say the paint used by the OP is OK at best. It scratches very easy and that's kind of a bad thing on some of these parts.
I used the same paint as the OP for my interior and noticed how much it scratched.
I decided to try out another paint and went looking for something suitable. I found this:
http://www.yourautotrim.com/satinblack.html
Pretty soon I can post a picture comparison. I tested the SEM paint on the visors in my brother's 92 Civic and a few pieces in his TT Supra. They look GREAT and seem to be much more resilient than the paint originally suggested by the OP. It sucks that you have to order it and can't just pick it up at Advance or something. But I think it's a much better interior paint.
Old May 7, 2009 | 02:52 AM
  #134
80210's Avatar
I'm getting my headliner redone and so I painted some parts black if you take a piece of tape and put it on there, then pull off it removes the paint!
I sanded too! Perhaps I will try to use primer although I thought I wouldn't need it on plastics...
Any input would be great.
Old Oct 16, 2009 | 10:29 AM
  #135
Greenspeed's Avatar
This is awesome, i did this about 8 months ago. Really helpful guide
