Removing rear o2 sensor on Evo IX
Old Jun 7, 2008 | 11:56 PM
hytek369's Avatar
no luck for me either. damn plug
Old Sep 9, 2008 | 02:05 PM
AIEvo9MR's Avatar
I don't have the special O2 Sensor removal tool. What size wrench could I use to remove it. Also, is the O2 sensor for the turbo outlet housing and cat the same. Thanks guys gals.
Old Sep 10, 2008 | 10:35 AM
lapulapu's Avatar
22mm... you can go barrow the tool from AutoZone
Old Sep 15, 2008 | 11:53 AM
AIEvo9MR's Avatar
^Thanks^. I was talking with my neighbor and he recommended that I heat it up with a torch and spray WD40 on it. With a bit of brute force it came off without stripping or breaking.
Old Dec 31, 2009 | 11:38 AM
supremellama's Avatar
Any bolts having to do with the exhaust piping should be taken out with patience and care. It's a bigger headache to get a rounded/broken bolt than waiting to soak it with pb blaster or something.
Old Nov 24, 2017 | 06:52 PM
Deadulus's Avatar
I just got done installing a high flow cat on my Evo IX and it was a absolutely painful taking off those bolts and the O2 Sensor. Breaker Bar is your only friend. Start off with it and you’ll be fine, I started to round the tips of my bolts and immediately went all out w the breaker bar and it was used to get every bolt out, even the sensor.
Old Nov 24, 2017 | 10:25 PM
deylag's Avatar
Another option is to disconnect the rear 02 sensor.
Old Nov 24, 2017 | 10:35 PM
Deadulus's Avatar
The sensor is already disconnected according to the ECU but the cord was cut so I just left it in for “looks” / “whenever I sell it” and have a wideband bung for my AEM gauge.
Odakrem
Oct 25, 2017 02:55 PM
Pandaxpress
May 5, 2017 07:00 PM
yellowevo82
10
Mar 17, 2017 06:42 PM
O0oDC
Mar 17, 2017 12:15 PM
EvolutionRacing
Apr 6, 2016 10:29 AM
