Sun hyper force ignition?
Old Sep 4, 2006 | 01:27 PM
jspecEVO's Avatar
I purchased a used one from another member on this board with no instructions. I know the how to hook up all the connectors etc. but, I need to know where the connector with the fuse attaches to. Any heelp would be gratly appreciated! Thanks in advance, Rob
Old Sep 6, 2006 | 08:59 PM
onpol's Avatar
I'm on the same boat as you.Help is needed to make sure where the ground points and fuse goes.
Old Sep 6, 2006 | 09:18 PM
eling99's Avatar
r u guys refering to the black wire with the loop end? if yes, that goes to the + side of the battery
Old Sep 6, 2006 | 09:21 PM
EVOlutionary's Avatar
+1. Fused wire goes to positive battery.
Old Sep 6, 2006 | 09:24 PM
onpol's Avatar
Thanks .And what about the 2 ground points where to i attach those?
Old Sep 6, 2006 | 09:27 PM
savageevo's Avatar
those two wires go to the bolts closes to the coil. just pick the ones that work neatly when you put the cover back on. good luck
Old Sep 6, 2006 | 09:28 PM
jmoudry's Avatar
The two ground points go under the coil pack bolts. Make sure you verify these ground points. I ran a better outside ground under the spark plug cove just to make sure.
Old Sep 6, 2006 | 09:29 PM
jmoudry's Avatar
Thumbs up
I got beat to the draw
