Boost Gauge Install
Old May 24, 2008 | 09:03 AM
Bunni34's Avatar
useless thread! thank for the upset!
Old May 24, 2008 | 01:48 PM
vortico's Avatar
There is no index.htm however there is an autogenerated page if you go to http://www.jonesland.com/evo/
That does contain the boost gauge installation information.
Old May 9, 2009 | 12:28 AM
mr.turbo's Avatar
howdie,
what about having troubles, because of tapping the vacline of the FPR - will not cause faulty readings for ECU / FPR ??
wouldn't it be nicer to tap the brakebooster vacline ??
should also be a nice source for vac/pressure readings, aye ?!
anyone already tried, experiences ??
- i found this, look :
http://www.sytyarchives.com/howto/vi...php&dir=gauges
is it correct, that evo's ECU/FPR readings do NOT suffer from tapping the FPR vacline, unlike the typhoon (maybe the differnce between MAP and MAF) ??
- i mean it's kinda logical for me, that when the FPR sees the vac/boost value after the gauge there'e a little bit of "delay" that can cause knock or worse IMO ...
just my 2cents (had a gmc typhoon before i got an evo )
THX 4 input, pat.
Old May 15, 2009 | 02:13 PM
Bunni34's Avatar
Try this out.
http://evomoto.com/tech_info.php?tPa...f01382daaaf239
Old Mar 10, 2011 | 11:46 AM
ariasdejesus's Avatar
Nice
Old Mar 24, 2011 | 10:06 AM
evo8mr03's Avatar
thanx man helped me out.
Old Dec 11, 2011 | 12:09 AM
NattyMyst1c's Avatar
Wil be doing this along with some other projects whenever I get my garage warmed up. Chicago winters. Go home.
Old Dec 15, 2011 | 11:45 AM
ssj2salami's Avatar
Boost gauge install
So that hole in the firewall, how do you reach it in the car? Is it up from under the drivers side pedals, or do you go in behind the radio?
Old Dec 15, 2011 | 11:48 AM
ssj2salami's Avatar
Boost gauge
Nevermind....I just realized that must be some drilled hole in the firewall....darn. Does anyone know of a hole that is already there from manufacturer that a person could run a gauge hose through?
Nomad4g63
10
Oct 6, 2013 06:09 PM
GTE28
Toronto Lancer Club
Sep 2, 2013 06:17 PM
mrdecibel
20
May 19, 2008 02:09 AM
number3
Jan 10, 2005 07:15 PM
mrdecibel
Apr 12, 2004 09:44 PM
