Defi Control Unit Warning Mode Help
Old Sep 8, 2006 | 02:48 PM
SMrider102's Avatar
I can't seem to figure out how to set the warning on my boost gauge. The default warning is set to 15psi, so everytime I start the car I set it to 21psi or so. Is there no way to make 21psi the permanent warning setting? Or does will it always reset itself to 15psi after I turn the car off? I hope this makes sense.
Old Sep 8, 2006 | 03:09 PM
kekek's Avatar
Have you tried reading the instructions?
Old Sep 8, 2006 | 03:11 PM
Anarchy99's Avatar
The Controlle unit needs a constent power sorce along with a switched 12v power that is why it resets it self every time you turn off the car.
Old Sep 8, 2006 | 03:19 PM
Anarchy99's Avatar
http://www.defi-shop.com/product/ima...nual06064e.pdf
Page 27
Red-Power
Orange-Ignition Power
White- Lights
Black- Ground
Old Sep 8, 2006 | 03:22 PM
SMrider102's Avatar
Thanks, i see where i screwed up
Old Sep 8, 2006 | 03:24 PM
Anarchy99's Avatar
That's why EvoM is here good luck.
TURBODAWG
49
Apr 11, 2015 02:55 PM
trevor
Feb 19, 2012 06:51 PM
0E3vobutt3r
Dec 2, 2008 09:20 PM
JDMevoBOOST
May 27, 2007 01:39 PM
nrcooled
Feb 11, 2007 12:45 PM
