quick question boost controller related
Old Mar 6, 2008 | 05:58 PM
0E3vobutt3r's Avatar
Question quick question boost controller related
I just got finished hooking up my HKS EVC V (Black-KPa)
I was confused and set my warn to 158 (about 23 psi) and I tryed to dial in my boost to 22-23, with the knob all the way down I was only holding 15 so about half way I hit about 21. I turned it just a little more and when I hit 22 PSI my car shuttered, kind of like I hit the brakes. Is that the warning? From what I read its just supposed to beep.
I've read 10 threads about this and I dont really see my answer.
any help would be nice
all warmed up, 3rd gear pull from about 40mph
EDIT: went out again, I was thinking fuel cut, I have a walbro in my room, (I know its not helping anything in there) I was goin to put in this weekend and I will finally be getting my laptop this weekend and getting a tune from 4 wheel slide
more info the car held 20-21 up until about 48-5200 RPM
Still sound like fuel? I hope so I'm running on my low setting at 17-18 PSI until my tune and fuel pump are in.
thanks
Buddy
Old Mar 6, 2008 | 06:07 PM
heel2toe's Avatar
was you car all warmed up when this happened?
Old Mar 6, 2008 | 06:16 PM
yes all warmed up, 3rd gear pull from about 40mph
Old Mar 6, 2008 | 06:18 PM
EVOVIII200's Avatar
i just a hallman pro installed on my car, i had a problem with that instant shutter, backfire or whatever you want to call it. i use to get a po234 code, which was an overboost which is maybe what you got when you have no tune or hose incorrect. i set my boost at 19.5 and it holds strong and no more problems.
Old Mar 7, 2008 | 04:36 AM
bump for more info.
one night I spiked 24 before I even did this controller and it never did this "shutter"
I'm going to mess with it more today
cheers
Old Mar 7, 2008 | 04:50 AM
ApacheFixer's Avatar
do you have a tune? it may be your boost cut
Old Mar 7, 2008 | 05:26 AM
phat_bastage's Avatar
Sounds like fuel cut.
Old Mar 7, 2008 | 09:24 AM
thanks
Buddy
Old Dec 2, 2008 | 08:50 PM
95lsvtec's Avatar
yea im having the same problem but im spiking at about 27psi.... i noticed it was pinging off the stock boost gauge(1.5 bar), so i installed the greddy electronic boost gauge tonight and just got on it after all warmed up, it hit 27psi then the boost cut happened.... come on everyone, help us guys out
Old Dec 2, 2008 | 09:20 PM
detroit pistins's Avatar
on a side note, how much does the stock ix boost at?
thanks,
riceclown
32
Jun 16, 2008 08:56 PM
SPOOLD
Dec 6, 2007 01:31 PM
xLaNcErEvOx
15
Nov 2, 2006 05:18 AM
Warrtalon
72
Jan 24, 2006 04:50 AM
BuCKxWiLD
Aug 25, 2005 10:31 PM
