How to modify your stock "lancer" gauge to accept useful gauges
Finally got around to installing the Innovate accessory gauge into my cluster. Install was easier than the required wiring and setup for the LM-1 which was a major PITA.
All of my interior lights are Red so it looks great at night!
Looks great. I was thinking of doing the same. Looks like you had to take the gauge apart it to get it to fit.
http://www.dynotunenitrous.com/store...?idproduct=150
I've seen this as well in the clock location. Is this all that is needed to monitor and Log?
I'm new so just want to make sure I get the right parts the 1st time.
here is something that i did to my gauge cluster.. i used a omori 45mm boost gauge. its electric and comes with map sensor. lot of trimming is required to make the gauge fit basically u have to make the stock lancer gauge 45 mm wide . onces it it 45mm wide u have to make is about .8 inch deep . after that u have to open the omori boost gauge and take it out of the case and place in the lancer gauge location. wire it up and u should be all set..
I did the same set up only I did not take the gauge apart.
Raist
